BARF - Bay Area Riders Forum
Old 11-03-2005, 05:34 PM   #31
elskipador
elskipador@gmail.com
elskipador's Avatar
Mod Alumni
Contributor
Motorcycles: the trickest f2 you've ever seen.
slowly remove the 10mm bolts that hold down the cam cap. work in the reverse of the tightening order, which is stamped on the cam cap. loosen them slowly. after they're removed, gently wiggle the cam cap loose.
AUTOBOTS MC 415 Ministry of Love Dunlop tire ninja
Track tires bikebandit honda kawasaki partsfish yamaha
where to get inked up worked here for 14 years the cheat is the sheet
where i got my degrees rules of barf new fuel
want me to fix your ride?
lizzie banet bryan "ol' man" paquette herb bogart
elskipador is offline   Reply With Quote
Old 11-03-2005, 05:39 PM   #32
elskipador
elskipador's Avatar
Mod Alumni
Contributor
slip the cam chain off the cam.
Old 11-03-2005, 05:40 PM   #33
elskipador
elskipador's Avatar
Mod Alumni
Contributor
remove the intake cam.
Old 11-03-2005, 05:41 PM   #34
elskipador
elskipador's Avatar
Mod Alumni
Contributor
use a magnetic pick-up tool to remove the valve bucket.
Old 11-03-2005, 05:45 PM   #35
elskipador
elskipador's Avatar
Mod Alumni
Contributor
remove the shim from the bottom side of the bucket. use this formula to calculate the new shim size.
A=(B-C) + D
A=new shim size.
B=recorded valve clearance.
C=specified valve clearance.
D=old shim thickness.
Old 11-03-2005, 05:48 PM   #36
elskipador
elskipador's Avatar
Mod Alumni
Contributor
repat for all valves that need adjustment on the intake. then put the intake cam back in and remove the exhaust cam and repeat. once all the valves are adjusted, replace the cams and cam cap. make sure all the timing marks line up. torque the cam cap bolts to 10 N/m. remove the flatblade screwdriver from the CCT and it will tighten up. recheck all valve clearances to make sure that they're were you want them to be. reinstall the ignition & valve covers, spark plug, wires, harness connections etc... and hook up your carb for a sync.
Old 11-03-2005, 05:50 PM   #37
elskipador
elskipador's Avatar
Mod Alumni
Contributor
this is the screw you turn to adjust the carbs sync. there is 1 screw between evey pair of carbs. adjust 1/2 1st then 3/4 and 2/3 to finish.
Old 11-03-2005, 05:50 PM   #38
elskipador
elskipador's Avatar
Mod Alumni
Contributor
pretty out of sync.
Old 11-03-2005, 05:50 PM   #39
elskipador
elskipador's Avatar
Mod Alumni
Contributor
after the sync.
Old 11-03-2005, 05:51 PM   #40
elskipador
elskipador's Avatar
Mod Alumni
Contributor
after that you're pretty much done, besides putting it all back together and going for a test ride
Old 10-16-2006, 01:11 PM   #41
yohuallin
yohuallin's Avatar
Motorcycles: 94 zx9r, 98 marauder 800 v twin
DO you think it might similar on my 94 zx9r?
94 zx9r (yoshi) still parting out
97 suzuki marauder (maraia) GONE
89 CBR SOLD
94 ZX7 (yoshi2)
86 ltd454
98 suzuki marauder... v twin
88 toyota corolla (1.8l fury)
91 TROOPER
93 dodge ram
yohuallin is offline   Reply With Quote
Old 10-16-2006, 01:28 PM   #42
ob1ventura
ob1ventura's Avatar
Contributor ++++++
Motorcycles: '05ZX10r, '01 FXD, '07FXDC
Excellent write up Elskipador. Thanks for taking the extra time.
Anyone care to do the same for a ZX10r?
ob1ventura is offline   Reply With Quote
Old 10-16-2006, 07:04 PM   #43
Stormdragon
Still Good Lookin'
Stormdragon's Avatar
Contributor +++ artist and BB
Motorcycles: XT600, ZX636, KR250, RS90
Niiice. Thanks for taking the time to take all the pics and do the write up.
Dirt, diesel, or deer. You've got to plan for the unexpected.
---Me
Stormdragon is offline   Reply With Quote
Old 10-16-2006, 07:36 PM   #44
enki
enki's Avatar
Founding Member
Motorcycles: Looks like Darth Maul's
I would like to mention that you have to loosen the radiator and move it down to slide the cylinder head cover out the front of the frame.
enki is offline   Reply With Quote
Old 10-16-2006, 08:58 PM   #45
elskipador
elskipador's Avatar
Mod Alumni
Contributor
i leave it alone and just slide the cover out the back.
