#1 |
Ask me about my B-1-D
AMA #3295113
Contributor ++ 2%
Motorcycles: zzr & xsr
gunsmithing question?
Hi Militia,
It looks like I may need to fabricate my own replacement extractor for an obscure single shot bolt action 22 caliber c & r rifle (Pieper Bayard #3) that holds minimal collectors value. extractor rotates on a pin in the bolt, pushed upon by a spring loaded plunger question : are extractors typically heat treated / hardened ? I am guessing no. please advise
Rust is my thread locking agent * 1 Thessalonians 5:8 "But since we belong to the day, let us be self-controlled, putting on faith and love as a breastplate, and the hope of salvation as a helmet." |
#2 | |
Motorcycles: None, but my brother has 54.
Hello Simon:
I am not a gunsmith, but for a .22, if made of a good modern steel, I wouldn't think so. Would you be able to make a dimensioned drawing of the part? If it is a flat extractor I could have one wire-EDM cut for you, which might save you considerable time. Ken Quote:
#3 | |
AMA #3295113
Contributor ++ 2%
is there a file format your machine prefers (drawing will be in autocad) thanks, —S
#4 |
Good Morning:
DXF if 2d, STP if a solid model. Thanks Ken |
#5 |
AMA #3295113
Contributor ++ 2%
Ken, sent u a pm
thx
#6 |
Merely Rhetorical
Respectful Contributor
Motorcycles: motato
Be sure to make two, or more.
This place sells some parts for that bayard https://www.gunpartscorp.com/
The wise speak when they have something to say. Fools speak when they have to say something. |
#7 |
Hello Simon:
Received your pm, thank you. I sent you one with my contact info. Thanks Ken Last edited by 900ss; 10-25-2020 at 10:26 AM.. |
#8 |
I decked a piece of D2 to .08" today and have given EDM your .dxf. Do you want more than 3 pieces? A loop and repeat program can make as many as you want within reason.
Everything will be cut to your nominal dimensions and you may of course need to hand-fit the machine bits. Let me know if you want any dimensions cut over or undersize. I will let you know when we're done. Of course, being tool steel these will rust if you so much as look at them. I hope this helps get your piece working again! Cheers Ken |
#9 |
Contributor + 1%
Motorcycles: gas
Ahhh nothing better than a barf love connection! Good on ya Ken.
FREE HAND JOBS__Teh Poopie Thread__Fetal Liver on Sale! "It's a joke. It's all a fuckin' joke. God help us all." |
#10 |
We should end up with 9 pieces.
#11 |
AMA #3295113
Contributor ++ 2%
yay!
#12 |
I lied, there should be 11 pieces. F'ing rabbits........
#13 |
AMA #3295113
Contributor ++ 2%
pics ?
my shop drawing :
Rust is my thread locking agent * 1 Thessalonians 5:8 "But since we belong to the day, let us be self-controlled, putting on faith and love as a breastplate, and the hope of salvation as a helmet." Last edited by GPzPop; 10-28-2020 at 05:40 PM.. |
#14 |
Pics of the rabbits? No no no, that is our company's intellectual property.
![]() I will check tomorrow on the progress; they were being hole popped today and will likely be wire cut tomorrow. Re: your dimensions, 4 place decimals usually denote close tolerances are required. I told the EDM manager (who does handyman projects on the side BTW: many of his clientele are in Woodside) - THAT IS A SHOUTOUT FOR HIM - to not make a finish pass on the parts. I.E. the wire will cut the parts once with no second "cleanup" cut. I think you will be happy with the parts cut this way, but if you prefer a cleanup pass please let me know. FYI we may do 2 to 3 cleanup passes on our high precision (and high $$$$ parts) for tolerances in the tenths or millionths range. I really don't think not doing a finish pass will detract from the function of your extractors, as they were probably hand fitted and finished in their original form. Do you have any small "needle" or Swiss pattern files? If not, Grobet makes excellent files that can be bought from Western Tool, which has a store in Livermore. If you do not have any and don't want to buy them let me know and I will put my set in with the parts. I mis-stated the material as being D2; it is actually O1. It's feeling a bit like Christmas! Ken |
#15 |
AMA #3295113
Contributor ++ 2%
I am really enjoying all the knowledge being dropped here after asking but a simple question
* * * * * I got reassembled and working another C & R 22 today, a Stevens "Favorite" 1915 which is a lever action falling block single shot I ebay'ed the replacement firing pin, which precipitated an internal disassembly to access the retaining pin, and a rust boil-out because it was apart already and needed it new firing pin leaves good strong impression on snap cap test Both of these rifles courtesy of my late FIL's arsenal
Thread Tools | |
Display Modes | |
