BARF - Bay Area Riders Forum
Go Back   BARF - Bay Area Riders Forum > Club House > Who Let the Smoke Out!?
Notices
Old 12-09-2020, 01:01 PM   #1
bergmen
bergmen's Avatar
Motorcycles: 2014 Yamaha FJR1300A
Kawasaki ZGRX 1200 Concours
Some of you may know about this project I started in April of 2007 and began first test rides in November of that year.
Briefly, I took the engine from a 2003 Kawasaki ZRX1200R, converted it to shaft drive, designed my own front engine mount and ended up with a 1200cc Concours (more than 25% more horsepower and torque).
There is a LOT more to this story that I can expand on if anyone is interested. BTW, once I had all the bugs worked out I rode this for seven years with zero issues until I got my 2014 Yamaha FJR1300A.
Dan
bergmen is offline   Reply With Quote
Old 12-09-2020, 04:44 PM   #2
Frame Maker
Frame Maker's Avatar
Contributor
Motorcycles: sportbikes, dirtbikes, and some odd bikes that I've built myself.
Originally Posted by bergmen View Post
...Briefly, I took the engine from a 2003 Kawasaki ZRX1200R, converted it to shaft drive, designed my own front engine mount and ended up with a 1200cc Concours (more than 25% more horsepower and torque).
There is a LOT more to this story that I can expand on if anyone is interested...
You're now in the right place, so go ahead and post up your story. And be sure to include lots of pictures, we like pictures
Frame Maker is offline   Reply With Quote
Old 12-09-2020, 06:52 PM   #3
budman
General Menace
budman's Avatar
AMA Life Member #203453
Highway Aviator
Founding Member
Top Percent Poster
Community Contributor + BB
Moto Junkie
Motorcycles: Keep me rocking life
The conversion to a shaft drive alone is worth hearing more....
budman is offline   Reply With Quote
Old 12-09-2020, 07:46 PM   #4
Maddevill
KNGKAW
Maddevill's Avatar
AMA #: 542337
Motorcycles: ZX14,GS750E, KTM 450/540
I agree.
Mad
Old 12-09-2020, 07:51 PM   #5
bergmen
bergmen's Avatar
Well,the original ZG1000 engine block is identical to the ZRX1200 block from the input shaft rearward. Same bearings in the transmission, same center-to-center spacing, same oil system, everything. Same rear engine mounts.
I needed to install a six-speed Concours transmission in order to have the bevel gear coupling on the end of the output shaft. The bolt pattern for the bevel gear was there in the crankcase output side with one exception. I needed to drill and tap one extra hole (the boss was there). The ZRX clutch basket (necessary for the ZRX primary drive) bolted right up to the Concours input shaft.
Here are pictures:
ID:	539873   Click image for larger version
ID:	539874   Click image for larger version
ID:	539875   Click image for larger version
Old 12-09-2020, 08:08 PM   #6
bergmen
bergmen's Avatar
Before I worked on the transmission change over I needed to design a new front engine mount. The ZG1000 engine was a stressed member of the frame and the cylinder head was mounted to the frame as a result (same as the Ninja 900 which this motorcycle was derived). The ZRX engine was not mounted this way. I designed a new engine mount using my 3d CAD system.
ID:	539882   Click image for larger version
ID:	539883   Click image for larger version
ID:	539884   Click image for larger version
ID:	539885   Click image for larger version
Old 12-09-2020, 08:12 PM   #7
bergmen
bergmen's Avatar
I was able to acquire a spare Concours frame to use for developmental purposes so I could leave my Concours unmolested during the engineering of this conversion.
Old 12-09-2020, 08:14 PM   #8
budman
General Menace
budman's Avatar
Highway Aviator
Founding Member
Top Percent Poster
Moto Junkie
Sweet.
Drilling the hole had to be the deal. Screw that up and start over.... with new cases. I am impressed.
Old 12-09-2020, 08:16 PM   #9
bergmen
bergmen's Avatar
The Concours shift drum, shift shafts and gear indexer arms mounted in the crankcase without modification. Here I am doing a complete function test of all of the transmission components in the ZRX case.
Old 12-09-2020, 08:25 PM   #10
bergmen
bergmen's Avatar
Sweet.
I mounted the bevel gear case to determine exact location of the hole to be drilled. I marked it with a drill of the same diameter as the clearance hole in the case. I then measured the depth of the other holes in the case and used an extension drill concentrically located in the case clearance hole to drill the pilot hole.
ID:	539889   Click image for larger version
ID:	539890   Click image for larger version
Old 12-09-2020, 08:25 PM   #11
bergmen
bergmen's Avatar
More tomorrow, I'm heading to bed...
Old 12-10-2020, 02:04 AM   #12
Pushrod
Pushrod's Avatar
Motorcycles: VTR, R100RS,CB500
Drilled into a case, got it square and straight, with a hand-held drill?
That qualifies for admiration.
Pushrod is offline   Reply With Quote
Old 12-10-2020, 05:37 AM   #13
kpke
kpke's Avatar
Contributor +
Motorcycles: many 2 strokes 06 R1 LE 158
EGADS. Subscribed. That is a really cool transformation.
I love the photo with the frame/engine supported by the galvanized pipe.
And all the other photos
Yes! Teh BRAF is O-K!
Ken's Garage
Motorcycle rides, shows, custom builds, and other stuff
kpke is offline   Reply With Quote
Old 12-10-2020, 06:58 AM   #14
auntiebling
megalomaniacal troglodyte
auntiebling's Avatar
BARF Moderator (ooh, fancy!)
Barfie Winner 2017
Contributor
Motorcycles: .
This is awesome
no shirt, no shoes: No dice BARF TOS
every book is a children's book if the kid can read
-mitchbarf memes
my dad is an engineer
17/38 sprockets
CARB bikes list CA DMV fee calculators
Classifieds Forum Rules
Originally Posted by Abacinator View Post
Love that subway tile backsplash, auntie
auntiebling is offline   Reply With Quote
Old 12-10-2020, 07:18 AM   #15
bergmen
bergmen's Avatar
It was fairly straightforward to maintain concentricity by using the clearance hole in the bevel gear case as a guide. I took my time and was very careful. I then tapped the hole (M6) with a taper tap followed by a bottoming tap I had to make myself (ground the end of a spare taper tap). Hard to find M6 bottoming taps in this town.
Dan
