BARF - Bay Area Riders Forum
Go Back   BARF - Bay Area Riders Forum > Club House > Reviews & Recommendations
Notices
Old 12-20-2020, 02:03 PM   #1
MoldTheClay
MoldTheClay's Avatar
Motorcycles: Vroomvroomgofast
Chain lube - Motul C5 brush on paste is good stuff.
I guess this is kind of an anti "which oil should I use" type of statement for a change of pace.
The Motul C5 chain paste is the first chain lube that didn't feel like a necessary evil. Every other spray based lubricant I have tried has let me down. Either due to being too light and causing a lot of fling to being too thick (to avoid fling) and instead becoming a glue trap for every bit of grit and grime on the road. I've always hated having to lube my chain because it felt like I was causing a snowball of maintenance where cleaning the fling or grime build up was as much of a chore as keeping the chain itself clean.
This stuff, however, brushes on instead of spraying to avoid over doing the job while neither being a goopy glue or a fling-able oil. Once the stuff heats up it melted into the x-rings and rollers providing a thin and very slick feeling layer of protection. The chain has stayed lubricated for the last 350 or so miles without finding its way onto the inside of my wheels, the underside of my tail, or the chain guard. Thanks to it not picking up every spec of road debris like the PJ Blue I normally use I was able to clean it off without creating my usual grime trail in the driveway as well. It forms a pretty thin slick barrier which came off without really any scrubbing. Spray on the solvent, work it in with a sponge, rinse it off. Ez.
Thus ends my unofficial Motul commercial. Get it, it's good stuff.
MoldTheClay is offline   Reply With Quote
Old 12-21-2020, 02:10 PM   #2
Busy Little Shop
Man behaving bikely...
Busy Little Shop's Avatar
Motorcycles: Honda RC45 RC30
I also recommend Motul Chain Paste... squeeze the white grease from the
tube and load the brush... Hold the loaded brush to the inside of the
chain rollers to transfer the white grease... After a couple of spins
of the chain it's lubed like from the Factory... Motul Chain Paste
clings with no flings...
Have a wheelie NICE day...
Lean & Mean it in every corner of your life...
If it wasn't for us the fast lane would rust...
V4'S are music to the seat of my pants...
1952 De Havilland Chipmunk...
https://www.youtube.com/user/BusyLittleShop/feed
http://s1036.photobucket.com/user/Bu...?sort=3&page=1
http://www.flickr.com/photos/55532474@N00/?saved=1
http://www.flickr.com/photos/10503451@N07/
Busy Little Shop is offline   Reply With Quote
Old 12-21-2020, 02:25 PM   #3
rodr
rodr's Avatar
AMA #: 2846730
Contributor + + + +
Motorcycles: CB500XA
Works great on sliding doors and windows too!
rodr is offline   Reply With Quote
Old 12-22-2020, 08:56 AM   #4
somesuch
Motorcycles: gsxr
I really like Dupont Chain Saver....no sticky mess, great chain life
somesuch is offline   Reply With Quote
Old 12-22-2020, 08:58 AM   #5
DucatiHoney
DucatiHoney's Avatar
AMA #: 1028914
BARF Admin
Barfie Winner 2014, 2017 and 2021
Contributor +
Motorcycles: Uh....it's a scooter. But in red, the fastest color.
moved to Reviews & Recommendations
DucatiHoney is offline   Reply With Quote
