BARF - Bay Area Riders Forum
Go Back   BARF - Bay Area Riders Forum > Moto > Riding Skills
Notices
Old 08-18-2019, 09:18 AM   #1
guycole
Rookie
guycole's Avatar
AMA #4140935
Contributor
Motorcycles: VFR 800, KLR 650
How to deal w/big wind
I680 between Benicia and Cordelia, I80 around Red Top road generates some amazing wind that blow my Interceptor all over lane. What can I do about it?
Perhaps some other tire? I have decent Shinko Advance tires inflated per the manual (36 PSI front, 42 PSI rear), etc.
Thanks for reading.
guycole is offline   Reply With Quote
Old 08-18-2019, 09:30 AM   #2
CDONA
Home of Vortex tuning
CDONA's Avatar
Motorcycles: Triumph scrambler, TW200, Monkey
Not so much a tire to fix this.
I can tell you about the solid wheels on my Fatboy and V-rod.
Add a big windshield to the Fatboy, it took on the characteristics of hanging on to a windsurfer. This happened on Nv 95 Vegas to Laughlin.
The Sacto causeway always gave me fits when the north wind cranks up.
Hang on loosely, give it some leeway, slow if it won't stay in your lane
Don't fall for the "pull my finger"
"Chip Tank" in Vacaville Ca.
Started hammerin' Honda 90's around Berryessa, Summer of Love '67
CDONA is offline   Reply With Quote
Old 08-18-2019, 09:54 AM   #3
budman
General Menace
budman's Avatar
AMA Life Member #203453
Highway Aviator
Founding Member
Top Percent Poster
Community Contributor + BB
Moto Junkie
Motorcycles: Keep me rocking life
That area is windy for sure. I have had some good bluster adjustments through there. The amount of mass that the wind can catch makes a difference as noted in the post above.
Tires would likely do nada. Just something Mother Nature expect you to over come.
At Willow Springs Raceway when it got windy some riders would remove their lower fairings to try and reduce the impact in the high speed shit that was perpendicular to the wind direction.
budman is offline   Reply With Quote
Old 08-18-2019, 01:51 PM   #4
bikewanker
bikewanker's Avatar
AMA #: 178394
Contributor ++++++++++++1%
Motorcycles: TR-650x2, , Rapid Taxi RR, Tiger 1050, ZX-6r, '81 1002 F
Drop a gear or two and lean.
Originally Posted by nebulous
“Being offended by the past using today's sensibilities, or un-sensibilities as it were, is disgusting”
"tis better to wank here than in the hereafter" M.S. Murphy.
"Rivers and roads lead people on" Georgia O'Keeffe
Be Well Ride Well
bikewanker is offline   Reply With Quote
Old 08-18-2019, 02:55 PM   #5
totalknee999
Rookie
Motorcycles: 999
Originally Posted by budman View Post
At Willow Springs Raceway when it got windy some riders woul remove their lower fairings to try and reduce the impact in the high speed shit that was perpendicular to the wind direction.
I'm with Budman. It was very windy in Colorado Springs when I was a novice in 1988 and all the fastguys were removing their fairings.
totalknee999 is offline   Reply With Quote
Old 08-18-2019, 03:20 PM   #6
davidji
bike curious
Contributor + + + 1%
Motorcycles: 2016 CRF1000L, 2007 R1200R
Agree about the plastics. If you're bike is acting like a sail in crosswinds, a different bike might be a good solution.
When I had a bike that responded poorly to crosswinds, it was better without the top case mounted. If you ride with a top case, and it has a negative effect, that effect will be less if you mount it to the pillion seat than on the rear rack.
More upright ergos can help as well. If you're putting weight on the bars, and your body gets pushed by the wind, is it translating into a steering movement? Does focusing on relaxed, shoulders and arms help in the wind?
Best bikes I've had in crosswinds were nekkid, though not all nekkid bikes I've ridden were great there. All but one I think.
"Honesty may be the best policy, but it’s important to remember that, by elimination, dishonesty is the second-best policy.” – George Carlin
davidji is offline   Reply With Quote
Old 08-19-2019, 12:00 AM   #7
bikeama
Super Moderator
bikeama's Avatar
AMA #: 1097
BARF Moderator
Contributor + 3%
Motorcycles: 2020 BMW S1000XR Lowride.
IF you have a bike with electronic suspension move it to sport and stiffen it up. Made a big difference on my K1600gt. Not as much a difference on the Multistrada, less plastic. Soft suspension makes the wind worse.
bikeama is offline   Reply With Quote
Old 08-19-2019, 04:16 AM   #8
NorCal Factory
Contributor ++++ 2%
Motorcycles: Aprilia Tuano, Aprilia RSV4, KTM 300 XCW
I ride a gear lower to keep RPMs up - more rotating mass and gyro effect. And sometimes go faster - more gyro effect from the wheels. Sometimes it is counter intuitive but faster is safer.
Other times it’s just too dangerous so I keep the RPMs up.
Give it a shot!
Tucking down also helps.
NorCal Factory is offline   Reply With Quote
Old 08-19-2019, 07:49 AM   #9
ejv
Untitled work in progress
1% Contributor
Motorcycles: Tuono
I feel it just takes a lot of experience to be comfortable getting tossed around a bit. I started riding in NM. New Mexicans will tell you they have four seasons. Summer, Fall, Winter, and Wind. The Spring can be real nasty there. After riding in high winds dozens of times for a few thousand miles, eventually it just becomes natural. I've not since ridden in anything like it in CA except one time two months ago when I was riding back from the central coast up 1 between approximately Point Sur Lighthouse and Garrapata State Park. Super gusty and two vehicles in front of me got partially blown off the roadway kicking up rocks and gravel. I picked up the speed to clear it ASAP because it was getting sketchy with all the large SUVs being pushed around. Anyway it was a good reminder about how high winds effect the bike. Probably a 10-15 mile stretch. After a few minutes I was back in my groove with it, after having not dealt with that kind of wind in over 10 years.
ejv is offline   Reply With Quote
Old 08-21-2019, 11:32 AM   #10
day004
Major PITA
day004's Avatar
AMA Life Member #538338
Contributor +++
Motorcycles: None. For now.
I grew up in Fairfield and lived with that wind forever. I found weighting the pegs a bit more than usual helped. Be sure not to white knuckle the grips too.
"Many people would rather die than think; in fact most do." -- Bertrand Russell
Pain is inevitable, suffering is not.
day004 is offline   Reply With Quote
Old 08-21-2019, 01:04 PM   #11
DucatiHoney
DucatiHoney's Avatar
AMA #: 1028914
BARF Admin
Barfie Winner 2014 & 2017
Contributor +
Motorcycles: 1994 M900 Ducati
Ugh, wind. I dislike that more than any other weather situation. I rode a Monster (so no fairings) over the BB regularly for years and still would get nailed by wind sometimes. I found that gearing down and tucking helped, as well as leaning into the wind. Often I would notice that there was an "ideal speed" for the wind too. Try speeding up or slowing down a little and see if you can find a happy medium.
9
s h e l t e r w e r k architecture.design
live::::work::::motorcycles
DucatiHoney is offline   Reply With Quote
Old 08-21-2019, 01:59 PM   #12
DrDave
DrDave
DrDave's Avatar
Contributor
Motorcycles: R 1250GS CRF 250x 1098
IMHO, most wind issues are wind buffeting the rider and that transmits to the bike through the handlebars. Loose on the grips helps tremendously.
Originally Posted by R3DS!X View Post
Sometimes these cars will try and chase me when I'm just trying to have fun. They never catch up but they do try. I think they are part of some car club cause they are always custom painted similarly and have flashing lights on top. Their horns sound unique too and they are always trying to distract me with them.
HoHo
DrDave is offline   Reply With Quote
Old 08-22-2019, 06:49 AM   #13
lvscrvs
Rookie
Motorcycles: DR650
Gen 1 Vstrom 650 and 1000 were terrible in the wind, especially with a taller Givi windshield installed. I attributed that to the tall windshield and the high COG that comes with adv type bikes. I would wager that a heavy cruiser with no windshield would be the most planted in the wind, but I'm just speculating because I've never owned one.....
lvscrvs is offline   Reply With Quote
Old 08-26-2019, 07:01 PM   #14
Mike T
Ahahahahahaahahahahahaaha
Mike T's Avatar
Top Percent Poster
Motorcycles: '99 Yami R6 (sold), Duhondayamawazuki ZXGR-4550RRR Limited Special Edition, 2015 883 Iron
I lean into it. I deal with wind and gusts in my area (Tracy) on I5/205. Kind of planted due to being a heavy (but naked) Harley.
Member of TPW+PHU Founding Member
..."Memento Mori & Adequito Ad Astra"...
"AHAHAHAHAHAHAHAHAHAAHAHAHAHAHAAHA"
..."Deuce-19's!"...
Newbie Ride #24
OG of Spartan Riders (since 2006 wo0t wo0t)
Mike T is offline   Reply With Quote
Old 10-04-2019, 06:34 PM   #15
Underdog
Prehistoric
Underdog's Avatar
1% Contributor
Motorcycles: '16 WR250R (3k) '14 Ninja1K (60k) '07 FJR1300A (93k)
Slow down and relax.
Underdog is offline   Reply With Quote
