BARF - Bay Area Riders Forum
Old 11-03-2005, 04:39 PM   #1
elskipador
elskipador@gmail.com
elskipador's Avatar
Mod Alumni
Contributor
Motorcycles: the trickest f2 you've ever seen.
How To: 98-02 ZX-6R & 03-0? ZZR600 Valve adjustment.
in this how to we'll look @ the valve adjustment on 1 of kawi's popular 600 from start to finish. the valve adjustment interval on this bike is rather short. unlike most shim-under-bucket valve trains, that require an adjustment every 15~17k, this kawasaki needs it done every 8k. kinda' a bitch since you still have to pull the cams twice as often as most bikes. you'll see what happens when you go 24k without looking @ them.
start by removing the lower fairings.
AUTOBOTS MC 415 Ministry of Love Dunlop tire ninja
Track tires bikebandit honda kawasaki partsfish yamaha
where to get inked up worked here for 14 years the cheat is the sheet
where i got my degrees rules of barf new fuel
want me to fix your ride?
lizzie banet bryan "ol' man" paquette herb bogart
elskipador is offline   Reply With Quote
Old 11-03-2005, 04:44 PM   #2
elskipador
elskipador's Avatar
Mod Alumni
Contributor
remove the front tank mount bolts
Old 11-03-2005, 04:44 PM   #3
elskipador
elskipador's Avatar
Mod Alumni
Contributor
pop off the rear seat and remove the 10mm bolt holding the front seat on.
Old 11-03-2005, 04:46 PM   #4
elskipador
elskipador's Avatar
Mod Alumni
Contributor
after the seat is out of the way remove the 2 10mm bolts holding down the rear of the tank. unplug the 3 hoses, mark them for the reinstall.
Old 11-03-2005, 04:47 PM   #5
elskipador
elskipador's Avatar
Mod Alumni
Contributor
remove the clamp and unplug the fuel line. turn the gas valve to the "off" position before removing the gas line.
Old 11-03-2005, 04:49 PM   #6
elskipador
elskipador's Avatar
Mod Alumni
Contributor
set the gas tank aside and remove the airbox and carbs.
Old 11-03-2005, 04:54 PM   #7
elskipador
elskipador's Avatar
Mod Alumni
Contributor
unplug the evap hose and crankcase breather, red. and the rest of the airbox lid screws, white
Old 11-03-2005, 04:54 PM   #8
elskipador
elskipador's Avatar
Mod Alumni
Contributor
remove the airbox lid.
Old 11-03-2005, 04:56 PM   #9
elskipador
elskipador's Avatar
Mod Alumni
Contributor
remove the air filter. the kawi's is a cleanable foam unit. its not that dirt, but its a good idea to clean and reoil in.
Old 11-03-2005, 04:57 PM   #10
elskipador
elskipador's Avatar
Mod Alumni
Contributor
remove these last 2 10mm bolts and the bottom of the airbox can be set aside.
Old 11-03-2005, 04:58 PM   #11
elskipador
elskipador's Avatar
Mod Alumni
Contributor
Old 11-03-2005, 04:59 PM   #12
elskipador
elskipador's Avatar
Mod Alumni
Contributor
unplug the valving from the carb vent and remove the valve.
Old 11-03-2005, 05:00 PM   #13
elskipador
elskipador's Avatar
Mod Alumni
Contributor
next remove these 2 screws in the back of the throttle housing. this will allow us to easily get the throttle cables off the carbs.
Old 11-03-2005, 05:03 PM   #14
elskipador
elskipador's Avatar
Mod Alumni
Contributor
unplug the wiring harness from the throttle position sensor.
Old 11-03-2005, 05:05 PM   #15
elskipador
elskipador's Avatar
Mod Alumni
Contributor
and the float bowl heaters. there are 4 of these. 1 on each carb.
