Mario
Active member
Hi all, first time rebuilding a two stroke engine, 2009 KTM 200 XCW, 70hrs on engine. Got new gaskets, put everything together following the manual instructions, perform leak down test and found 3 leaks:
1) slave clutch cylinder gasket,
2) clutch cover gasket (the big one, not the small clutch cover),
3) cylinder base gasket
I disassembled everything (but the cylinder head) to fix #1 and #2, cleaned the surfaces, lightly sanded with 1500 grit on a wooden block to remove any imperfections (did not change surface finish), greased gasket and reassembled. Testing again, I get the exact same leaks in the same places.
Any suggestions on what I an do? I can think of testing with oil in the engine, hoping that oil might seal those leaks (??). Next I can think of is gasket sealant but don't see why I would need to use this if I do a good job with the surface preparation.
Regarding cylinder head, the leak is minimal, very tiny bubbles. I am using a double gasket as instructed per manual. I expect seal might not be tight and will get sealed once exposed to two stroke oil? I torqued the cylinder nuts per manual torque.
Thanks!
PS: leak is around 5psi drop in 10 seconds
Thanks!
