Bike: 07 R6
Use: 20% highways; 80% twisties/trackdays
Pace: mellow twisties; 6C/2B group trackday runs
Age: 10 months on street bike; very many heat cycles
I just replaced my first set of Michelin PP 2CTs at 3.8K miles, with 50% and 20% treads left on front/rear. I would not hesitate to continue using these tires (as I've experienced no issues on them); I only replaced them because I have another set in my garage since Feb and wanted to clean my garage.
During those 3.8k miles these tires offered excellent grip at 38/38 psi on the streets/twisties (sometimes running 36/36 psi when doing "spirited" speeds, not often) and 31/30 psi on the track. No slips or other issues due to them; always predictable.
The dual compound really works to get the tires even wear, same good grip through the tire life plus the extra assurance of more grip on the edges (although I don't know if I had ever needed the extra traction, but it is good to know that it's there). In fact, when I took them off, they had a bit more tread in the center than sides.
Previously I've used Dunlop Qualifiers (single compound) tires, and they did not wear evenly (center wore out first) and I felt their grip lessen with use (I replaced my Qualifiers at 4K miles (running 36/36 psi on street/twisties and 32/32psi on track) and they were definitely done by then (nearly at the wear bars both front and rear).
Given the longivity and good performance of these PP2CTs tires, I'd definitely recommend them. Although they are a bit more expensive to run, but I feel because these PP2CTs offered the same, good grip through out their life, they are a good value.
