09-14 R1 Frame, Carbon subframe and swingarm
holycowman
huffy-pusher
San Francisco
PK-Ripper
750$,
Divorce. Moving. Now.
As shotty as it is, it is. Thinning out and moving.
09-14 R1 Frame, and swingarm, one piece carbon tail (left seam will need attention - I can cut you off a yard of carbon and set you up with a good resin)
I started on the buildup to make these to pull plugs from to have molds for a full carbon setup, won’t have room or time to finish. Moving as I type this. If you want It stock shave it off. You can go either way. Or if you like, I can include the carbon matrix and continue.
Either way, gotta go.
Thanks.
