I have a 25k mile garage queen that's taken out once a month and brought up to freeway speeds to get up to temperature, but otherwise sits a lot. While I use a fuel stabilizer, it does take a few months to empty the tank. Recently it started having an issue with cold starts, stalling on the first and sometimes second start. It also has issues with low RPM bogging even while warm, hesitating to rev up from idle 1300k to about 3-4k before it suddenly becomes responsive. While riding at 6-7k and low speeds (or maybe thats the only time I can hear it), it will sometimes backfire even with an even throttle input. It sounds a bit like popcorn, 1-2 per second in spurts.
The throttle bodies are synced, the TPS sensor reading is good, the air filter is clean, and I just replaced the (normal looking) plugs which made no difference. Fresh fuel hasn't helped. HOWEVER a full tank does, though not completely. The hesitation improves a lot, but it still backfires. Today as I was starting it on the sidestand with 2 gallons in the tank, I noticed the fuel pump making an unusual sound, like its cavitating and pulling air. Standing the bike fully upright (or with a full tank), the fuel pump sounds normal. Here it is on the sidestand, 2gal in the tank, when I flip the kill switch to on:
My theory is its a partially clogged fuel filter and/or reservoir cup inlets, but before I pull the tank wanted to float that with those more experienced. Thoughts?
Also if I do pull the fuel pump assembly, which parts should I have on hand to replace regardless? I'm thinking the sock filter and o ring.
Thanks all.
Thanks all.
