2017 KTM 1090 Adventure R Quick Shift?
MikeL
Active member
Peninsula
None.
Mike
I can't find anything via Google searches, YouTube, or the actual manual. I can't find a review that mentions it having a quick shifter either.
Does anyone if it actually has a quick shifter or is this just some incorrect menu option?
Try to shift it without the clutch at half or more throttle and see if it cuts the engine. That should tell you.
All of the options are available in the menu regardless. For example, turning on the heated grips shows up even when you don't have them installed.
I don't know if this applies to your bike but I got a '19 1290 recently and the quick-shifter is there but you have to pay to have it enabled. Thousands of dollars for a bike and then KTM charges 500.00 or so to turn the quick-shifter on. That plus a couple of other things have turned me off to KTM.
The 1090's didn't come stock with quick shift. Did you get the optional "Travel Pack" p/n 60700900100? It won't work without a dealer activation. It also enabled Motor Slip regulation (MSR) and Hill Hold Control (HHC).
Lots of bike’s cost thousands and don’t include a quickshifter.
Isn’t it likely that your bike was cheaper initially because the quickshifter wasn’t activated.
Im currently not seeing the downside of having options installed that can later be activated for a small cost.
Wouldn’t the quickshifter apparatus attached to the gearshift lever be visible.
I should have elaborated some. The quickshifter mechanism is in the bike and ready to go, except that it's turned off and can only be enabled by a dealer through KTM. A salesman tried to explain the logic about being competitive price-wise with non-quickshifter bikes but since it's all in the bike already it didn't make too much sense to me. KTM must be able to sell the bike for a profit without activating the quickshifter so it seems chicken-shit to me to charge another 500. Seems bumping the list price a little and selling it enabled would be better marketing, but who understands the world of marketing?
