GB500guy
Active member
- Joined
- Jul 12, 2015
- Location
- Vacaville
- Moto(s)
- 1975 Honda CB125S
1989 Honda GB500
1989 Honda NX250
1989 Honda CB-1
1997 Honda CB50V
- Name
- Bill
Finished her up
Excited to get the cylinder head back the next day, I spent the other evening out in the shop prepping and finishing up whatever other assembly I could do. With 35,000 miles on the clock I wanted to replace the cam chain, but did not want to split the crankcases to do it. But David Silver sells a rivet-type master link, allowing replacement by breaking the old chain and the new chain, then riveting back together. As it turns out the old chain showed less elongation than I had expected for the mileage, another testament to the value of the owner's frequent oil changes.
I installed new countershaft and rear sprockets to go with the new chain on hand. The oil pump got tear down for inspection and all new O-rings since it was one of the major leaks.
The ignition advance got disassembled, cleaned and lubed, and I installed and static timed new points.
All cables got cleaned outside and lubed inside.
Had to stop and pet the shop mascot, then stepped outside to watch the full moon behind fluffy clouds. Rain was forecast for the next day so that would make for a perfect shop day to install the head.
My buddy brought the head over the next day, and after leak testing we installed the valves and torqued it down. Here the cam is in and we're ready to crank the starter to confirm oil pumping to the top end. Two steel tubes running parallel to the cam have small holes that squirt oil directly on each cam lobe. As well, the cam lobes dip into an oil bath with each revolution.
Last thing for the day was bolting on the cylinder head cover and calling it a day.
Next morning the coils went back on. The plug caps have been cleaned inside and out and a thin coat of dielectric grease applied to the insides and wire connections. Is it just me, or are cooling fins just a beautiful feature of air cooled engines?
By the end of the day the bike was complete - valves and cam chain adjusted, carbs installed and synced, timing set, and that gorgeous exhaust system installed.
Then of course it was test ride time! The bike is just an absolute joy to ride. It runs like a top and has rock solid handling and electric motor smoothness.
A few more glamour shots:
This has been a fun and very satisfying project. I will be doing a few shakedown rides and followup tuning before reluctantly handing the key back to my buddy, the bikes owner. Then we will be hitting the road for some nice rides, two old friends on our vintage bikes, just like the old days but for all the grey hair. Ride pics to follow.
-Bill
-Bill
Stunning... absolutely stunning.
