glf said:(snipped)
the area highlighted with the red circle was actually located where the red arrow is pointing to, when I first dissasembled it. I don't know if this is of any particular matter, or if the shift star just goes around in circles with the shifting......my question. should the section (missing the pointy part - circled in red) be located by the little shift arm (Stopper Comp, de) or does it matter where the star is rotated to, when it is assembled.
my thought was that this is why it wasn't shifting properly.
the snap rign on the left side of the bike was fine. albeit it greasy and dirty, which I cleaned.
When the trans is in neutral, the bearing on the detent arm should rest in that depression; that's what you're feeling in your foot when you're searching for neutral.
I have my stock '03 star in my hand right now; Zoran's right, the two locator pin-pockets on the back are offset so there's no way you could put it on the drum backwards. Unless you left one of the two pins out (I don't know how easily they come out of the drum).
http://www.ronayers.com/fiche/300_0305/gear_shifting/gear_shifting.bmp
You did have those two dowels (#8) in that drawing, right?
luckily I pulled the cover off, saw that it was loose, and is why it wouldn't rotate the shift star, hence not shifting the gears.
