I prefer drum brakes for good reliable performance.
I see what you did there...
I always thought the holes in discs were for hot gases that build up between the pad and disc to escape, not for cooling. It seems like a vacuum pump on the motor would be better served as a supercharger, not to cool brakes. Why not just space the disc out farther from the wheel so it is in open air like Ducati did on some of their race bikes?
BARFer with the dad that is an engineer...
From the organic compounds in the pads when they get hot.
got any evidence? what do u mean by hot? if u mean "at a high operating temp", i doubt it. if you mean "melting off the backing plate", then ya sure.
an organic pad may combust and produce gasses outside of its designed operating temperature... but dont you think that hot gasses are the least of your worries at this point? wouldnt the solution to that problem be running a pad designed for the extra heat, not drill holes in your rotors? of course, this is more speculation on my part but i gotta keep the convo about vehicle myths going somehow.
Found this pic which sorta helps:
http://www.motorbeam.com/wp-content/uploads/EBR-1190-RX-Wheels.jpg
Honestly, the comment about there being a vacuum pump powered by the engine makes absolutely no sense IMHO. Looks like there's just ducts.
Wow, the thread title itself explains it, the concept makes absolutely no sense and has no evidence to support the assertion, and most everyone STILL missed it.
Don't judge a thread by it's title!![]()
^^ even with fairings I'd say far more air flow on bike rotors than those tucked away in car wheel wells?
This raises the question of why are most modern bikes fitted with cross drilled rotors but there are no cracking issues there?
