{brag} The Lick Observatory is using my photo for their FB banner now.
I took this earlier in May
Very nice! Can you tell us a little about how you took that?
Sure. I'll go for a little bit too much information maybe?
First, a little Milky Way information.
The Milky Way "season" is roughly from March->September.
Early in the "season", the Milky Way comes up in the east, horizontally, early in the morning ( say 3-4 a.m. )
By September, the Milky Way has moved to the South-SouthWest, and is vertical and appears early... like 8-9pm.
Summary = When you see a Milky Way photo that is horizontal, it is taken early in the year. When it's vertical, its taken later in the year.
The brightest part of the Milky Way is called the "galactic core" (essentially we're looking at the center of the MW) - after September, it dips below us in the Northern Hemisphere and we don't have as dramatic of a view. In my image, the galactic core would be the part in the right 2/3rds of the image... the part with the most white. On the extreme right edge of the image, the light pollution from Morgan Hill/San Jose bleed into the image.
The image I took here was taken at the end of May at around 12:30 a.m.
It's actually a composite of four vertical photos, stitched together.
In order to accomplish this type of photo, you need a tripod and a camera that lets you control how long of an exposure to take - for this photo, the images were 20 second exposures. The more time for the exposure, the brighter the MilkyWay is - but if you leave the exposure open too long, then you start to get star trails. (There is a formula which says you shouldn't have your exposure more than 500/focal length = a typical iPhone has a 28mm focal length, so 500/28 = ~17 seconds would be the longest you could go for that focal length before the stars looks less like pinpoints and turn schmeary.)
To get even higher quality images, some astrophotographers use a tripod that can "track" the night sky; essentially, the tripod moves at the same rate as the earth so you can have longer than 500/focal length exposures. This is beneficial because you can have your camera use the sweeter part of its (ISO) sensitivity range.
The Lick Observatory photo I took May 30
I was in Yosemite on May 1st for this at 2:30 a.m. {horizontal, early in the year}
And I was on the corner of Hwy 25/198 October 1st at 8:30 p.m. for this {vertical, late in the year}
But these weren't taken on an iPhone, right?
The other technique nowadays is to stack shorter images and post-process them, right? Did you do any of that?
Is it as visible to naked eye as your camera captures? I've gone to Yosemite for many years hoping to see it. Have gone to Glacier Point late late in to the evening and can only see thousands of stars. Bad timing perhaps?
