wannabe
"Insignificant Other"
I tried to do a search, but I came up empty. Sorry if these questions have been asked and answered a bunch of times already.
I'm going to be replacing the bleeder nipples on my bike with speed bleeders. I'm trying to make sure that my understanding is correct on how to use them. I know that they have a one-way check valve that doesn't let air go back into the system. My question is related to the bleeding process.
Before the speed bleeders, the process with the regular bleeder valves was something like:
1. Put hose on bleeder valve
2. Pull brake lever
3. loosen bleeder valve about 1/4 turn and let stuff squirt out
4. Tighten bleeder valve
5. Let go of brake lever
Do the speed bleeders allow me to skip a few steps? In other words, once I put the speed bleeders on, will I be able to do this?
2. Open bleeder valve about 1/4 turn
3. Start pumping brake lever as much as you want to get the fluid out while making sure to keep the fluid in the reservoir topped off
I do know that there is a chance that air might still get past the edges of the bleeder valve, but assuming that doesn't happen, can I just crack open the speed bleeder valve and pump away on the brake lever?
2. Pull brake lever
