BigB
Mr Honda #849
- Joined
- Mar 19, 2003
- Location
- Mountain View
- Moto(s)
- 14 CBR 1000RR Street, 09 CBR 1000RR Track
- Name
- Bryan
- BARF perks
- AMA #: 2743740
I will test with a GoPro for ya...
That footage turned out really well! Did you do any modifications to your Contour HD to improve sound quality?
They do and you guys can gladly use the tripod mount I have if you don't want to buy one.If there is a tripod mount for a GoPro, you can be the first one.
I thought about that for a while, but I couldn't come up with a suitable solution. I knew I wanted to keep it small to reduce the amount of strain on the servo unit. The gear that comes out of the servo is not a shape that anything can pass over. It has a beveled edge so that all the pieces (that your supposed to use with it) can have a firm hold on the gear. So I worked from there. I don't know of anything off the top of my head that has the same shape, so I had to work with what would fit over (and work with) the servo.
I would like to make this as small as possible, but I think that the screw and RAM ball will be just fine. The screw actually provides support for when you hit all those pot holes out on the roads. Lets face it, the tail takes quite a beating when riding on public roads. I am going to cover the bottom of the screw with rubber and put it in a case so that it doesn't touch the moto plasticsIf this setup only saw smooth racetracks, then floating the camera might be an option, but I quickly learned that you can't do that on the highway.
I do need to pick up another RAM ball mount because when I drilled this one, I didn't get it perfectly straight. I just figured I would give it a shot and see if it worked. Since it did (quite well actually), I will pick up another one and make sure to get it perfect this time. I will turn the sensitivity down on the gyro just a tad as it looks like its over compensating just a bit and put this all together in a portable(ish) package and give it another shot the next dry weekend.
They sell a ram ball mount with the universal camera screw built in!
http://www.ram-mount.com/CatalogRes...d/082065077045066045050051055085/Default.aspx
Or you can just do this
http://www.ram-mount.com/Portals/0/Skins/NationalProducts/images/acameramount2.jpg
