ST Guy
Well-known member
Moly moly MOLY MMOLY moly
. Yea, I know.... I'm always going on about it. But the stuff really is good. And tungsten disulphide is even better.
to the old girl.Belts work great but there are limitations on how much HP/torque a belt can handle given a certain size belt. And there are limits on how large you can make the belt before it causes lots of design problems.
I might even clean it first.
Adjusting your chain means the factory installed grease is failing and metal to
metal wear is happening behind the X rings... after the 3rd adjustment the
amount of wear will indicate new chain and sprockets...
This is what we don't see behind the X rings... metal to metal wear
every time we adjust the chain that eats into our engine's available
HP... a new pin measures 206.5 and wears down to 205.5 at the 8K mile
mark... looks good to the naked eye but multiply that 1 thousand of an
inch times 108 links and you have 108 thousands of an inch wear or
about the range of the green marks provided by Honda's wear gauge...
202.8 show the very visible wear at the 12K mile mark... the pins are
turning red from extreme heat of grinding dry metal... a chain in this
condition may consume up to 6 to 8% of our RWHP... not to mention it
may snap into and cause case damage...
Im going to look for that moly based stuff today and lube my chain. Start showing someto the old girl.
