2003 Gixxer 1000. I made the mistake of letting my sister with her Hands of Death start the bike. It had been running a moment before, and I shut it off so she could try starting it. She pulled the clutch in, and then pressed the start button, but just sort of "tapped" it... enough to start turning over, but not enough to start. She let her thumb off, and everything went dead. No lights, no nothing. Dead.
I've pulled the negative battery cable, waited, put it back on (suggested by someone that it might "reset"). I've checked the 15amp ignition fuse, it's fine. [Checked the 30amp main fuse, it's fine.
I don't know what else to check. I'm absolutely lousy at anything electronic.
Battery was replaced just about a year and a half ago. I haven't had ANY problems with it starting, ever.
Somebody please help, because my Mom's gonna feel really bad when I kill my sister. :|
zrex said it. Check the 30 fuse at the starter relay
sounds like she already did.
i'd yank the battery, get it load tested. at 1.5 years old it's unlikely to be dead but it could be. do you keep it on a tender?
bike was running for a little while, stopped then immediately started. that could have drained the battery but not let it recharge for the Sister OF Doom attempt
hmmm
i'm gonna go ahead and ask this since nobody asked...
is your sister still alive? :|
I am aware she said that, however she may simply have looked at the fuse rather than actually test it. The fuse may very well have failed.
Remember, KISS(Keep it stupid simple/Keep it simple stupid)
, and checking the battery fits right into that schemeyour mastery of acronyms is remarkable, and checking the battery fits right into that scheme
hmmm
The more important question, of course, is.......
wait for it
wait
almost there
is
she
hawt?
Connie, I gots big fuses if ya need em also.
She's still breathing. Oxygen won't run out for another 24 hours...
Dude... I mean, aside from the fact that she's my sister, which makes it an automatic "NO!", she spent years as a lead vocalist for a punk band... draw your own conclusions...![]()
