VeloceMoto
OK, how about this oneLess junk on there.
Tried to make the green area on the 'film' blurry looking, which is how it would appear.
I did it!
I bought a used D70 last night for a really good price and it came with the 18-70mm f/3.5-4.5 AF-S DX lens. After playing around with it for about 15 minutes last night, it's wayyy more camera than I can use right now--perfect, just what I wanted. I'll be able to grow into it and learn a lot, I'm sure.
I found this yesterday, and it clarified a lot of things for me. Anyone find any faults with the info provided within?
OK, so I'm reading something in the manual about CPU lenses. Do I have a CPU lens, and what is it?![]()
Ok, so I put the camera in manual mode to take a picture ...but it doesn't take a picture. It focuses and then sits there, mocking me.
When I turn it to full-auto, it takes pictures. What am I doing wrong?
Yes, your lens has a CPU. Any lens with autofocus, and plenty of those without, will have a chip in it that communicates with the camera regarding focal length, aperture, focus distance, etc.
Need more info. The thing nismodan mentioned is not the problem. The camera will take a picture in full manual, no matter how far off your settings are. Th point of manual mode is that you are in full control, and the camera will not try to outsmart you.
How do I calculate my effective focal length when not using an SLR with a full-frame sensor?
We're loving the new camera. I'll have some shots on here tonight.
Can you say 700 shots in 3 days?![]()
Can someone explain to me why an f/1.2 costs more than an f/1.4 and an f/1.8 (significantly so!). What's so hard about making the window open wider?![]()
You're assuming that the window opening is the limiting factor. It's the size of the window that makes the difference. Every time you step up in aperture size, the physical glass needs to be bigger also.
