ctwo
Merely Rhetorical
Maybe not like you think
That's kind of the neat thing about the beads- they balance the entire wheel assembly, rim/tire/etc. every time it comes up to speed. Unlike a static balance, where the weights applied to the tire balance the tire at that moment in time, but over time as the tire wears, the balance of the tire changes, but the weight placement does not.I’ve found that rims are more out of balance than the rubber, and once the rim is balanced the whole assembly pretty much stays that way.
One drawback being that apparently the tire needs to be going 50+mph before the beads can balance.That's kind of the neat thing about the beads- they balance the entire wheel assembly, rim/tire/etc. every time it comes up to speed. Unlike a static balance, where the weights applied to the tire balance the tire at that moment in time, but over time as the tire wears, the balance of the tire changes, but the weight placement does not.
I disagree with that- watch this video. The balancer test is showing that they're fully balancing at about 15mph or so. Takes about 2-4 revolutions of the tire for the beads to settle into place.One drawback being that apparently the tire needs to be going 50+mph before the beads can balance.
