P777
Member
I will appreciate an advice on ways to downshift when the traffic light turns red upon coming to a intersection, let's say at 50 or 60 mph. How do you downshift when you make a quick non-emergency stop?
Thanks guys. I am not looking for anything fancy. In my commute back and forth to work I get in a situation from time to time of a short yellow light before changing to red at 50 to 60 mph speed. I tried both options discussed here when it came to a need to stop, pull the clutch with applying brakes while downshifting to the first gear, and the alternative way of downshifting gears from 5th to 1st. It looks like both options are in use per replies here. What is recommended more by riding instructors for going down from speeds above 50mph to stop for intersection situations?
This topic comes up regularly once or twice a year here. I disagree with the idea of keeping it in gear at a light. It takes less than half a second to get back to first gear if I detect the need to be in gear, and I expect to need way more time than that to be able to determine that I might need to "escape". The harder part would be determining where to escape to.Yes, "never" put the bike in neutral at a stop.
Mind, I'm known to violate that when there's several cars behind in the lane.
But as a general rule, keep the bike in gear, to that escape route you have planned can be used (you have an escape route, yes?).
A key strength of motorcycles is being able to get out of the way.
That is usually a sign of a wandering mind.In all of my decades of riding, I've never once had to escape from someone coming up behind me.
You've missed shifts into first? I didn't think that was even possible.If you're in neutral, there's some chance you'll miss the shift into first and it'll take longer to scoot out of the way.
