Earplugs and noise level ratings for motorcyclists
GTIMK4
Toronto, Canada
Kawi6R
OK - this is a HUGE post, but since I was trying to answer this same question on another board, I figure I'd just copy and post for your info.
I use the 3M 1100 cordless plugs. You should be able to get these at any Acklands or Unisource outlet in your area.
There is a LOT of good info about sound deadening ratings and how they are calculated on the links contained in the page below:
[I had to kill the link because it was screwing up the entire page]
Here is some excellent info on a how much we are exposed to while riding and wearing a full face helmet:
http://www.isvr.co.uk/at_work/m_cycle.htm
"Noise levels under motorcycle helmets
Noise levels under motorcycle helmets can be very high. Above about 65 km/h or 40 mph the wind noise generated by the airflow over a motorcycle and rider exceeds the noise from the motorcycle itself. Daily noise exposures of working motorcyclists may regularly exceed 90 dB(A).
We have measured noise levels at the ears of police motorcyclists in a wind tunnel and on the road, with several different helmets and motorcycles. Noise levels in the wind tunnel were similar to those on the road.
The graph above shows some examples of noise levels measured under motorcycle helmets during our tests on the roads. Although both BMW motorcycles were ridden by the same person wearing the same helmet, the noise levels differed. The BMW 1100LT has a windscreen which can be raised and lowered, and the noise levels varied with the height of the windscreen. The Kawasaki was ridden by a different person with a different helmet.
The measurements in the wind tunnel showed the main source of noise to be the turbulence at the edge of the windscreen's wake acting on the helmet. The rank ordering of helmets by the noise level depended upon the motorcycle and in particular the windscreen height - a helmet which is relatively quiet on one motorcycle can be relatively noisy on another and vice-versa. Low windscreens direct the turbulence to the base of the helmet, and modifications to improve the helmet seal around the neck can reduce noise levels on motorcycles with low windscreens. High windscreens direct the turbulence to the helmet visor and forehead, and modifications to improve the sealing of the visor to the helmet shell are then effective. Such simple modifications to helmets can reduce noise levels by 5 to 8 dB at the ear.
Wind tunnel tests with a flying helmet containing active noise reduction earmuffs demonstrated that noise levels as low as 70 dB(A) at 80 km/h and 80 dB(A) at 115 km/h were achievable at the ear. Similar systems within a motorcyclist's helmet suggest that this potential will not be realised unless the earmuffs are well isolated from the helmet shell and liner. Another method of achieving similarly low levels is to wear good earplugs. Many police forces in the UK are now providing these for their motorcyclists.
If you ride a motorcycle and your hearing sounds muffled afterwards, or if your ears ring, then you are suffering temporary hearing damage, which, if repeated regularly, may become permanent hearing damage. We recommend you consider wearing earplugs under the helmet. Because the earplugs reduce the noise, you may seem to be travelling more slowly, so take extra care to check your speed until you get used to the earplugs.
This project was carried out for the Home Office by ISVR Consultancy Services, the Department of Aeronautics and Astronautics, the Wolfson Unit for Marine Technology and Industrial Dynamics, and Hampshire Constabulary.
We have also measured the noise exposures of motorcycle patrols for one of the motorist breakdown rescue services. The measurements were carried out during the motorcyclists' normal duties to determine whether their full-day noise exposures were below the limits of the UK Noise at Work Regulations.
References in the open literature:
M.C. Lower, D.W. Hurst, A.R. Claughton and A. Thomas, 1994; Sources and levels of noise under motorcyclists' helmets. Proceedings of the Institute of Acoustics, 16, pt 2, 319-326. ISBN 1 873082 59 2.
M.C. Lower, D.W. Hurst and A. Thomas, 1996; Noise levels and noise reduction under motorcycle helmets. Proceedings of Internoise '96, Book 2, 979 - 982.
Here is a chart signifying what are the max "allowable" values and what are the values we encounter on a day to day basis. Note - when it says motorcycle, that doesn't mean inside the helmet at speed, as it does on the above post.
http://www.headwize.com/articles/hearing_art.htm
90 dbA 8 hrs
92 dbA 6 hrs
95 dbA 4 hrs
97 dbA 3 hrs
100 dbA 2 hrs
102 dbA 1.5 hrs
105 dbA 1 hr
110 dbA 0.5 hr
115 dbA 0.25 hr or less
Note: When the daily noise exposure is composed of two or
more periods of noise exposure of different levels, their combined
effect should be considered, rather than the individual effect of
each. Exposure to impulsive or impact noise should not exceed
140 dB peak sound pressure level.
Figure 2: OSHA Regulation 1910.95 - Occupational noise exposure
As seen in the OSHA Noise Exposure table in figure 2, the louder the sound, the less time it takes for damage to occur. OSHA limits noise exposure levels in the work environment to about 90dB for an 8-hour period, but permits exposure to higher levels for short periods. Many experts believe that the OSHA numbers are too high for hearing safety. EU countries have very strict laws about noise exposure. For example, U.K. employers must take action at two levels of noise exposure: 85dB and 90dB. At 85dB, employers must offer hearing protection and hearing education to employees. At 90dB or higher, employees MUST wear earplugs, and the employer MUST try to reduce the ambient noise level.
60 dB Everyday conversation, ringing telephone.
70 dB Restaurant.
80 dB Heavy city traffic, alarm clock at 2 feet, factory noise, vacuum cleaner, garbage disposal.
90 dB Subway trains, motorcycle, workshop tools, lawn mower.
100 dB Chain saw, pneumatic drill.
110 dB Dance club.
120 dB Rock concert speaker sound, sandblasting, thunderclap.
130 dB Jet take off, gunfire.
Figure 3: Decibel levels of common sounds.
**************************************8
SO WHAT DOES THIS ALL MEAN:
If an ear plug (like the ones I posted above) are rated for 29 dBA then you -7 from that and divide by 2. You get that number, which is about 11dB and you subtract it from the noise level.
SO - if it is 100dB inside the helmet and you subtract 11 dB then you are actually exposed to 89dB.
Since 89 is the UPPER limit of exposure, you might want to consider ALWAYS wearing earplugs.
gonna mark this post :thumbup just in case I ever get cited for earplugs in CA, I'd fight it till the law was changed.
No way am I risking my hearing because some legislator doesn't know jack about noise levels on a motorcycle
I read on that free motorcycle news paper that if your wearing custom made ear plugs you can not be cited. I think there is some loop hole that in order to get custom plugs a doctor must approve the amount of sound suppression so you can still hear a siren.
Any truth to this?
Rob
friction zone
Yeah that article was in Friction Zone magazine.
Here's a synopsis:
_______________
Are Foam Earplugs Legal?
Sergeant Price's Response (summarized):
Most store bought ear plugs are illegal. "Only customized personal (meaning made specifically for you) earplugs or molds can be used. However, you should consult your physician and obtain personalized custom hearing protectors whic are legal and will aid, rather than inhibit, your motorcycle riding."
blah blah blah.
________________
I'll still be wearing my Walgreens earplugs. I'm sucha rebel. :cowboy
see that's what I'm talking about. The legislation also says if it can damage your hearing you can use'em, its a grey area that I'd be willing to fight if I got cited.
Re: friction zone
pepperell said:
\Most store bought ear plugs are illegal.
screw that, if i ride for any real distance i wear ear plugs. but just in case, anyone know how much those custom plugs run?
i'm guessing they are pretty spendy...at least $30 prolly closer to $50 bucks. but the next time i'm at my doc's i'm gonna ask him for a prescript. if insurance will cover them and/or their cheap i'll get em.
if not, i'll just carry the prescript with me and wear the friggin drug store ones and if i get pulled over and questionned, i'll just show the prescription. like some cops going to know what prescription earplugs look like.
EDIT: a screw up
Just have your Doc write a scrip for "earplugs/hearing protection when riding a motorcycle under load conditions". You're all set, even with over the counter plugs.
In any case, I'll pay the ticket if it comes to that. Damn if I'm going to harm my hearing over a legislative misqueue.
Here is another intersting post from a guy in another forum. Basically he is saying that a lot of the damaging noise happens at frequencies we can't even hear at. Very scary. I don't think they are legal here either, but I really don't care. I'm not going to suffer hearing loss because some bozo is writing dumb laws. Actually, you can't hear people talk when you are in your car with the windows rolled up, can you? You can still hear sirens and such..... same goes for earplugs. BTW here is the other guys post:
I notice the motorcycle graph is in dBA. This a bad choice for assessing possible ear damage as it underreports the true impact arguably by quite a bit for motorcycles. The actual noise in the helmet will be MUCH higher than shown.
dBA mimics human sensitivity to sounds so emphasizes sounds in the 1-4kHz range more than sounds at different frequencies. This means it is useful to assess the "annoyance factor" of noise but not the possible damage impact. It suppresses sounds significantly at lower and higher frequencies. Over 20dB at 100 hertz and more than 50dB at 20 hertz!
dBC scale is used for human sound damage impacts as it is flat over a much wider range. Significant because a loud sound at 20 hertz may seem barely audible but it will still damage the ear. Unfortunately even dBC attenuates sounds below about 50 Hertz (about -7dB at 20 Hertz) so it also under-reports the damage effects of low frequency noises (but not nearly as badly).
This is very significant on motorcycles because wind noise dominants at speed and a lot of it is in the low frequencies. This means it doesn't seem loud but it is still ruining your hearing.
NOTE: Because of the unique aspect of motorcycle helmet noise at speed, dBC isn't totally valid since there is significant spectrum BELOW human hearing which will damage hearing (although the exact extent of sub-audible sounds damaging audible sensitivity is poorly researched). For that Z-weighting is preferred.
All this means the actual noise will be a LOT higher than shown in the graph. So as people have mentioned: use ear plugs (and ones with a good sound reduction rating)!
By the way all this has implication for anyone considering a motorcycle communications unit. Not every system works with earplugs. Riding down the road letting 110 dB+ in the helmet plus adding voice that is 20 dB louder so you can hear it is a great way to become deaf.
Cool info..Thanks... I am a big ear plug subscriber..Not only do they make my ears happy... the noise reduction allows for greater focus and seemingly a reduction in the feeling of the speed I am going. Everyone on the track should wear them always!
Good post! :teeth
:smoking
I have suffered hearing damage from m/c riding. It was in the 4000hrz range. I'm one of the very few people alive that has regained hearing loss! My loss look just like the m/c racer hearing loss graphs. The 4004hrz range is right were the human voice makes constinent sounds. It can be hard to distinguish what some one is saying (i.e. "tub" or "cub") sounds the same when spoken softly and conversations are very hard to undertand in resturant settings. For everyones info, the Cadillacs advertise they reduce road noise by 50db, and ear plugs can only do it from 10-20db!
WEAR EAR PLUGS!
Canyonrat2
Damn I must have some damage to my ears too..
so often I can't quite make out what the hell the wife is saying..:laughing (Love ya honey,,just kidding..kinda :p )
:smoking
Only problem is...I tend to lose my earplugs, they just disappear, poof! The customized ones, at $20 or more would probably get lost as well.
I'll use the cheapies from Walgreens and take my chances with the long-arm of the law on that :hand :later
Good point!
I was more interested in some nice custom plugs with the string so I wouldn't loose them. lol
rob
An interseting fact; it is legal for deaf people to drive in CA (but not legal to wear non-perscription ear plugs or headphones in both ears)...
