Dan Mechanical
Got a doozy of an electrical issue and I'm wondering if you guys can help me out
This issue is intermittent, so much of my troubleshooting is meaningless
One cylinder is not firing. I can tell by the sound, lack of power, and strong gas smell.
The tachometer shows near zero rpms and dances around a bit, even at high rpms.
I have deduced that I have an electrical issue somewhere in my ignition system. To prove that it is not the engine or plugs, I have done the following: Run the engine with spark cable disconnected while the issue was not happening (remember it's intermittent). With either cylinder disabled, I still showed correct RPMs. So... the issue is isolated from these components.
I've done the following electrical troubleshooting steps, but since it's intermittent, they are mostly invalid.
- test 12V to each ignition coil
- test omhs on each ignition coil
- test connection (2 wires) between the ignition coils and the ignition coil igniter
- test connection (4 wires) between the ignition coil igniter and the pickup coil
- test ohms on the pickup coil
- reseat all connections in ignition system
- inspect pickup coil by removing generator case cover
The issue seems to appear when the bike is hot. Once I stop riding, it cools off and the issue goes away, making it hard to diagnose. Because the issue is heat related, I am currently leaning towards a problem with the pickup coil because of its proximity to engine heat. Yes, I measured the correct ohms, but most likely when the issue was not happening.
Any advice? Are there any common shorts to look for? Has anyone seen this issue with the tachometer?
