- Joined
- Jun 19, 2002
- Location
- Walnut Creek
- Moto(s)
- Monica Sweetheart!!!!
- Name
- Berto
- BARF perks
- Barf Racer
Trailbraking is uselfull in 180 degree corners, I find. Sears 7 and 11 are great for it, as corner speed is limited by the tightness of the turns. In fact, it's easy to run a diamond patter in 7, and while not able to carry the corner speed, my entry and exit are much faster than a traditonal apex...
Trailbraking is done only with the fronts. The rear is used on some of these turns, but that's only to pivot and slow the rear from rising too high off the ground (cause the rear wheel, once off the ground, acts like a gyro, carrying the back of the bike higher faster). The rear brake really doesn't slow a bike much, but does aid in control. This was one of my important lessons this season. Really good one too!
Trail braking allows deeper braking, but at the expense of the contact patch safety margin. Trail too hard, too deep and the possibility to overload the suspension becomes high. Anyone see Nichy Haden Tuck the front at VIR? Not quite the reason, but close...
The real problem with trailing it in is the difficulty to steer the bike without putting it on the gorund. At some point, there has to be a decision to let off the brake and get on the gas. If you guys get into trouble, yell at yourself in your helmet "GASSSSSS" and do it. It'll save your asses more than once!
