ST Guy
Well-known member
after letting the bike sit overnight, put the bike on a front stand and spin the front. are the brakes dragging?
if yes, check caliper misalignment? caliper bolts bent? bent / misaligned axle? brake pad alignment?
Disk brakes will always drag just a little bit. The puck is never supposed to fully retract. Otherwise, every time you needed to use the brakes, you'd have to pump them up with the lever. Just an FYI.
