zixaq
So now that the drama of getting the bike home is done, the tedium of figuring out the problem starts.
2004 FZ6, bought last week from AK Motors in Santa Clara
Symptoms:
When turning key on:
1) display goes blank
2) display goes through normal startup routine, goes blank when I push ignition button, OR
3) oil, fuel, N lights start blinking (it's doing this consistently now)
Exactly one time, I managed to get an error code:
I got it push-started twice, and it would idle okay, but when put into 1st it died.
Troubleshooting so far:
-No obvious loose connectors or damaged wires around the front end
-Battery cables were tight on the terminals
-Battery reads 12.7V across terminals
-Fuses all appear (visually, did not check with a meter) to be okay
Can't troubleshoot anymore right now (dark and raining), but if this looks familiar to anyone, I'd love any ideas that might help me figure this out faster.
Symptoms:
Fault code: Er-1
Diagnostic Code: --
Symptom: No signals are received from the ECU.
Probable cause of malfunction:
Open or short circuit in wiring sub lead.
Malfunction in meter.
Malfunction in ECU.
