johnkol
Active member
Talked to Garmin at length last time, it doesn't have enough room for the data points it needs. They must've cut down the number on the 3790. Sounds like older or other ones had more.
It appears that Garmin may not have understood what you are trying to do -- or maybe I don't understand what you are trying to achieve.
Your 3790 already has the standard North America map, right? So what you are looking to do is have a topo map on the unit, then create routes on your desktop computer, and download these routes to your unit so you can navigate in real time, right?
The way you do this is insert a microSD card into the microSD slot of the unit, connect the unit to your desktop, then download a CA topo map (free from GPSFileDepot) to the card.
Then create the route you want on your desktop using Garmin Basecamp, and once you're done, download the route to the microSD card.
You then disconnect the unit from your desktop, power it up, and import the route you created. The unit will recognise it and display it on the standard NA map, or you have the option to combine the NA map with the Topo map.
I can't imagine why the 3790 would not be able to do the above. My 1450 can do it and it only has 2GB of internal memory (and I have added a 4GB SD card). Your 3790 has 8GB of internal memory, so it has enough space to accomodate hundreds of custom routes.
What specific step did Garmin tell you that the 3790 cannot accomplish?
I'm currently using the
