Eldritch
is insensitive
i guess i'll be buying me some jelly jars soon...and vodka too![]()
Don't forget a good charcoal water filter.
brita???![]()
Wouldn't common consumer filters impart an aftertaste? Especially from all the plastic.
my faves to do are beet and avocado infused vodka...separately. beet makes an awesome bloody mary.
Bacon. I can't speak for the final product....I'm not sure anyone else can, either.![]()
Beets moonshine is an evil.
I don't get it. Do you eat the pineapple? Or drink the vodka and it tastes like pineapple?
You used THAT much pineapple? Seems like using that much would make it way too sweet, especially since pineapple already has juice seeping out of it.
I'm interested in trying celery leaf.
LOL, it's like fermented borscht!
Remember, the only real difference between the mid shelf more expensive vodka and rotgut vodka is how many times it has been activated charcoal filtered
absolutely 100% not true
I was in before the editabsolutely 100% not true
shitty vodka taste shitty because the distiller tries to stretch out the heart by adding more head and tail.
Vodka should be primarily ethanol (the heart) but in the distillation process methanol (the head) and oils (the tail) are created as well. When the stream begins, a distiller collects it in a bucket. He should be fairly consistently checking the streams texture (methanol (the head) tends to feel colder then it is and feels dry). Once it begins to feel room temperature and wet, he changes buckets and begins drawing off ethanol (ie the heart, pure vodka)... he then keeps checking the feel and once it begins to feel slippery he is drawing off oils and flavors (the tail, imparts bad flavor)
Vodka is distilled to 160 proof and then watered down to 80. Vodka should be pure ethanol, which is virtually flavor less and "lacks" the alcohol taste. When you "taste" vodka you are tasting the methanol and the oils. Can you filter this off, for the most part you can filter a lot of it off... but don't think because it's been filtered 100 times it's better then a good vodka that's been filtered once. A GOOD vodka should only be filtered to remove visible impurities. A shitty distiller will try and capture as much ethanol as possible during the distillation process, inevitably capturing excess methanol and oils and thus requiring filtration. A great distiller will try and capture the least amount of methanol and oils, allowing for virtually pure ethanol.
/rant /science
we need to chat about "purification" i'm going to be getting a "water purifier" soon.
i've been doing a lot of research reading of the past week and my understanding is that the cheaper vodkas and grain alcohols are generally run through a column plate still at full speed once. while The reflux plates are more efficient at distilling then pot stills, at full speed you get a lot of fusel oils and harsh alcohols that lend to a very hot drink.
The top-notch artisan stuff goes through multiple runs at lower speeds with closer attention paid to separating out the spirit run from the heads and tails.
I am not an expert nor even enthusiast as I prefer Brown spirits but I've heard that Grey goose is deceptively mediocre by those that enjoy vodkas.
If you are an outdoor grower, put your male plants in a bottle of vodka. Could use female I suppose but that would be a waste.
After a month or so make a lemony little concoction similar to a Kamikaze that I like to call a Ganjakaze.
Be prepared for people at your parties to inexplicably fall down.
