aszrael1266
Resident Squid
So I've never played with or tried overclocking a pc and was wondering if some one could give me some advice on overclocking. I would to run the pc between 4-4.5ghz. I figured that shouldn't be to hard of an overclock range for me to hit.
I ran 3d mark vantage while having cpuid up so you can see an idea of what the idle temps are and the temps under a load. also had up cpu-z to see info on the chip.
As far as the system goes its an AMD FX-8120
Motherboard is MSI 990FXA-GD65
I have a corsair H60 cpu water cooler.
Idle core temps are 18-20C temps under load are as high as 41C while running benchmarks.
