OK it's official. I have the NSR in my possession.
The good news, it's street plated and all I have to do is go update the reg at the DMV.
The bad news... It needs a lot of work.
- Tank is rusted... Need to see how bad it really is and see if any of those cleaners/coat things will actually work on it.
- Front forks are shot to death. Leaking like crazy with cracked seals. Quickly reading through planet minis, it looks like someone local at RJP Racing can rebuild the front end off of NSR50s and put in stiffer springs for our weight. Any other alternatives outside of RJP Racing thats local?
- Rear shock also looks like it needs replacement.
- Rear brake master cylinder may be leaking.
- Hand controls throttle/clutch are squeaky and just need to be replaced all together.
- The motor apparently ran fine a couple of years ago before the thing sat untouched and not stored properly for 2 years. When I flipped the petcock, fuel started spewing from what looked to be a tube.spout from the carbs. The bike is a 92, what are the chances that this thing can be resurected back to life for less than the cost of a 4stroke motor? Since it's street, it would be nice to be able to just ride up to the gas station and not have to worry about pre-mix.
So if anyone has any spare NSR50 parts, let me know what you have. It looks like I have a complete rebuild here in my hands.
In terms of the motor swap, I would very much like a new motor but can someone give me a more realistic ball park estimate $ after mounts and custom work that needs to be done?
A quick google search shows just for the engines:
CRF150 - $2,000
Kitaco 124cc - ????
Lifang 150cc (17hp) - $700
CRF100 (?hp) - $550
GPX 140cc (11hp) - $450
CRF50 (9hp) - Maybe I can tear apart my CRF for this...
What about the knock off CRF/XR50s? What motors come in those?
Darren, I'm still in SJ but am in LA quite a bit as well now. You're right about the pipes though. I didn't even think about that yet.
That CRF100 motor with the NSF100 pipe would have been perfect.
