RockyMt
Rocky
Running 'em on a ZRX1200, Recomendations on "street" pressures?
Thx.
-Rocky-
Thx.
-Rocky-
I'm seeing all these astronomically high pressures and always higher in the back...wow! I started with 33 front 32 rear and worked my way down to 32 front 29 rear. That's on the street, 90% twisties and on a sportbike weighing 420ish wet. YMMV
I think the reason to run the rear higher is to get better mileage out of it. I know on my KTM it RAPED rear tires like that was it's purpose in life, but higher pressures helped a bit.
I got my first set oh Pilot Powers on the R1 back in 06'.
I normally run sportbike tires at 30psi front/31psi rear for spirited riding and 34/36 for commuting.
At the time the PP's were THE tire and everybody were hyping them up.
With 30/31 pressure I was imediately unimpressed. I called Alex Florea [AFM Michelin provider] and he recomended 36/38. If I remember corectly it had something to do with the higher silica compound.
They imediately felt better and since 06' I've had at least 4sets of Pilot Powers without any problems even ridden in a spirited manner.
I would at least recomend trying how the bike feels with PP set at 36/38 psi before dismising it.
When I firt got a set on my CBR 600 F4 back in the day, I ran 34 front 38 rear and it did feel good. Once the pace started coming up the rear started letting go earlier than necessary and this problem was greatly reduced by lowering the rear until I eventually got to a sweet spot of 30 (and I'm not talking track right now, where I also ran PP2CTs for a bit, but at 31front/30rear or a pound less each).
The front does feel good at 34 but depending on the bike setup and riding style will feel just as precise at 33 or 32 however will offer a bit more grip and feedback before letting go.
If I were to strictly ride the concrete jungle on a heavier bike (I commuted on a 5th gen VFR last year on PP2CTs too) I'd run 34 front and 34 rear...just bump that rear down to 32 for the twisties![]()
Junkie
34 front 36 rear. Ish maybe sometimes.
Why exactly do you run less pressure in the rear? Isn't it the front end you want more grip on?
But, I know guys that swear that they have to use cut slicks on the street for their mad skilz yo, so what do I know? Of course, they never seem to go any faster than I do?
