question on 2 stroke piston ring locating pin
Mario
Member
San Jose, CA
Track and dirty ones
Hi all, I am finishing a 2 stroke build (my first one) and got the cylinder back from Edco with a Wiseco piston. I am about to install the rings and found out there is only one locating pin in the top and just a hole in the bottom ring, no pin. Both rings look identical. Is this supposed to be this way or should I contact Wiseco for a replacement?
Thanks!
I would contact Wiseco. The ring pins stop the ring from rotation. If they rotate, the ends can get caught in ports causing major damage.
I read their website before posting, I didn't find anything related to the second groove. I thought there might be a reason why it is not installed... I'll give them a call tomorrow.
There open Sundays?.:laughing
Monday! I'm so tired of wrenching I don't even know what day it is! I need to go ride... :ride
This
On 2 strokes the rings must be retained in place. If there is no pin , the ring is going to rotate, catch the port and probably destroy the bore. I'm starting to question Weisco's quality control. This is not the first time I've seen this.
Mad
Need two pins. Yours fell out for what ever reason. Call Wiseco and they will surely send you a replacement.
I use Wiseco in my YZ250, but if you are uncomfortable with using them going forward and still want a forged piston, Wossner is available.
Called Wiseco, very quick to dismiss me and send me back to the engine shop, "you got to deal with the engine shop, good luck". Thank you!
Luckily Engine Dynamics (guy is amazing) was very helpful, asked me to ship the piston back and will ask to ship a new one straight to my place. Will ask for his advice on this. I hope it didn't "fall out" of the groove because if that is a possibility during manufacturing/shipping, it is a possibility it will happen in the engine and that would be catastrophic.
A friend had his KX125 bore destroyed by a locating pin falling out. Not sure if it was Wiseco. Those pins should NEVER fall out.
Mad
I can keep it in place same way I do the rest of my bike: a dab of RTV or maybe safety wire it? :teeth
Seriously though, anyone know if there is a best option for this? The ring ends looks to be shaped in a way that it would hold the locating pin in the case it become loose, but still, if there is a better option, I would pay the extra $ for it.
I have only read of this happening one other time over on Thumpertalk many many many years ago. If you do an internet search, I don't think you are going to come up with many examples of this. If it were a prevalent issue, I'd think there were be more internet "evidence." That's just my opinion based on anecdotal evidence.
I would tend to agree with you, once installed, it would be pretty tough for one to come loose unless the rings failed. But I am not a pro mechanic or engineer.
As for options, the Wossner piston is generally accepted as the higher quality piston. That said, even after reading about your experience, I'll probably continue to use the Wiseco piston in my two strokes without loosing too much sleep. Sucks that it extended your rebuild down time, but I wouldn't hesitate to use another one... with both pins of course. :laughing
There are folks that will bag on Wiseco pistons and or their much maligned crank and only use XXX. But it's probably the most common non OEM replacement used, most folks have zero issues, myself included. I even have one of the maligned cranks in a motor with a couple hundred hours.
Not saying its right for everyone or every application, just been my experience. :dunno
Bottom line, I wouldn't fret installing the replacement.
Aren't these usually a tight press fit? If it fell out you are lucky it fell out before you installed the piston and not after!
@OaklandF4i: Makes sense, I am installing the same. I bet this was just a manufacturing issue and it didn't fall off
@arsenix: betting on manufacturing problem and lack of quality control
Thanks all!
Yeah Wiseco is really hit or miss with their support. I've got one guy who was awesome and technically smart. And another who sounded like some hillbilly kid who didn't know anything.
Call again and tell them you want a replacement because the shop has nothing to do with the piston missing a pin.
