tzrider
Write Only User
It can take away lean angle too, which might be what he meant. I can’t tell.
My goal when going over lower traction conditions is to get the bike as upright as possible before getting there, then don't make any moves until I get to where there is more traction again. That definitely means getting the bike as vertical as possible, aim straight, get off of the gas and brakes, and maybe even pull in the clutch. I'm confused as to where counter-steering fits into all of this other than maybe using it to help get the bike as upright as possible.I don't see "this" mentioned as of yet here...
the technique that makes an experienced rider ride over slippery stuff and not crash is that of "counter-steering"... when the slippery stuff is found / visualized - an experienced rider will adjust trajectory of the bike for some counter-steering which will keep the bike upright over the slippy stuff.
... just like a skier in the mountains is constantly adjusting trajectory of skis over ice or slush, where you look and where you want to go need to coincide together.
the counter-steering skills are best learned on smaller bikes and usually in the dirt where it really just becomes "natural"... can even be learned on a bicycle.
Nope. Now it's more confusing than ever.CounterSteering is the same as it is in a car.
You are picking the bike up a little sacrificing your intended tighter trajectory to allow the wheels to slide over something easier and not allow the bike (in this case) to fall further towards the ground.
CounterSteering is changing the arc of your turn to a wider arc, either with a slide or picking up the bike.
Make sense now?
Make sense now?
Countersteering on a standup Jetski will make you look like a putz.
It took me years to find out why![]()
I learned to jetski when I was around 6-7. This is probably the reason I don't use a whole lot of bar input to turn a bike, unless absolutely needed (S's at Sonoma, etc.). Bar pressure is almost always pretty low for me.
Scott, my approach is similar except that I normally continue to roll on the gas gradually to help stabilize the bike and optimize traction.
