I don't entirely agree. out of the showroom floor, they have designed the system for the "average" rider. Now some of us are that rider, and for them things should work well. But some of us are not average (I'm lighter than average). So for me, getting the correct springs and adjusting the oil levels to my weight makes a big difference. Then especially for street use, where the roads tend to be more bumpy than the track, having forks with less stiction makes a huge difference (you feel the bumps directly up until the point they break through the static friction!). Necessary...well that depends on how and where you ride, but reducing stiction will make the suspension work better giving you more traction, confidence, and comfort. I like the bike to be more capable than me. You can send the stock forks in and have them polished, springs changed, oil adjusted, etc, or you can buy higher quality shocks (I personally like Öhlins, but there are other good ones) that simply have a lot less stiction. Then naturally, you need to ride them and have someone knowledgeable help you set SAG, rebound, preload, etc appropriate to your riding style. And note, your riding style will likely change (if you are improving) which will require you adjust your settings, so this can be an iterative process. But even if you are just cruising around and not improving, the first setup is important and will make a big difference for comfort and control...unless you are lucky enough to be the "average" they designed the suspension for.
