beginner
The goal today was not to see how fast I could stop the bike but to feel loss of traction from braking at the lowest speed I could arrange. To do that I did sort of reverse braking by applying the brakes as gradually as possible and still have some energy for a slow speed skid near the end. That worked. The tires got loud and I could feel the bike get squirrely close to the stop but I had no sense of a locked wheel and none of the sandpaper sound that might be associated with that. I used both brakes on every stop. I had no sense of the rear getting ready to lift off the ground. I'll watch for that. May be going up a hill helps because it keeps more weight on the rear end. May be the Kenda tires don't have the greatest traction, which I've complained about before.Sounds like you had a good time. Enchanter is correct, if you're leaving skid marks...well, they're called skid marks for a reason. Start with less rear brake and as you slow, release pressure on the rear while progressively squeezing the front.
BE CAREFUL. On a bike such as yours you'll really compress the front so don't be surprised by it. If the front skids, release the front brake and reapply.
By standard, if it's taking you at LEAST 36 feet to stop then you're nowhere close to the standards...going 20 you should be able to stop in under 25 feet. I'm sure we posted the ALT MOST standards somewhere in one of these threads so I'd go back and look there--it's an MSF set standard so it's doable.
http://www.youtube.com/watch?v=yQpJDux_M-w Watch the front end compress (we often call it LOADING the front) while I make that firm progressive squeeze. Good luck. Be careful, without a coach to walk you through it it's very easy to have a moment of "discovery learning" and end up on you head.
Before garaging the bike I did some hard stops from 30 mph on the road in front of the house both up and down grade with black marks and tires screeching. It never felt umcomfortable. Tomorrow is another day. There will be brake runs at the start of every PLP session from now on. I'll try to wear out a set of brake pads in the next 6 months and see what that teaches.
I watched your video and how the rear lifted up. I had no sense of that happening with the KLX.
