Toecutter
Member
Hey All. I have an 05 yamah TTR 230
I'm haveing problems with accerlation. The bike boggs down, like it is starved for fuel or something. then it sputters and will eventually pick back up. then you shift and the same thing happens again. In all gears. sometimes it back fires.
bought it used with 10 hours on it. ran great when i got it. started to slowly run like crap. did all the normal maintenance, oil filter, spark plug, air filter, chain, etc.....nothing worked. Took the carb apart and cleaned it, and to see if i had a clogged jet or something.....it all looked great.
took it to the shop and they drilled out plug to get to the fuel/air mixture screw. made some adjustment. And there is some improvement, but i am still having problems on the top end, 2 gear and up.
I heard ttrs are notorious for these kinda problems.
Should I rejet it???
any suggestions on how to fix..
PS the needle is not adjustable. I can go up on the main jet.
