This is regarding a Comer 50 cc goakrt engine, apparently a piston port setup.
-i know it has spark
-it has enough compression to push my finger out of the way when I cover the spark plug hole, pushing as hard as I can while pulling the string
-if I spray starter fluid in the intake, it will cough
low-carb jet and emulsion tube are clear, compressed air passes through and the carb is NEW
-dellorto 1412 baby flat slide carb
BUT
It never seems to pull enough air through the intake (none so far as I can tell) to get the gas to flow out of the float bowl and into the carb throat.
I know very little about actually working on 2 strokes. It's weird to me that I can't get any kind of vacuum signal at the intake manifold but it has compression.
Is the crank seal totally gone?
Before y'all get all "why isn't this a motorcycle" shush. I could put it in a bike frame. It happens to be in a race kart my kiddo was given and he badly wants to go faster than his now too small power wheels will go.
BUT
That is , if it will blow your thumb off, it has enough to run. You should test the motor for leak down. Not the standard 4 stroke type, but block off the exhaust and intake, making a method of putting air into the crankcase at about 6 to ten psi. Let stand and re check pressure. Crank seals should hold pressure, if not it's an air leak into you're mixture. Possible leaks are: crank seals, seal between the case joints, leaking base gaskets, and anywhere air can enter the crankcase. If it will hold pressure, that's not your problem. If it leaks, check all of the above with pressure and soapy water. A method of pressurizing is to put a schrader valve into a plate that you use to block the intake, or the exhaust. The real way involves use a crankcase pressure test kit that has a squeeze bulb, and a gauge . You can sometimes plug the ex or the in with large rubber plugs. Don't go overboard on the pressure, as you can blow the seals. Best to use a bicycle pump, or other hand pump. If no gauge available, put in a few pumps, let it sit, and press on the schrader valve and listen for a hiss. There must be a seal on case for a 2 stroke to function.
