I want to see pics too. I am still in research mode.
My biggest concern at this point is the heat retention. If one were to spray it down with water, would it bring temps down to a more comfortable level? I know it won't be like natural grass, but warm fake grass is better than hot concrete.
I compare it to concrete because they seem to cost the same. My quotes came in at roughly $10/sqft. for both surface types. Less expensive and more expensive quality of both surface types affect price similarly.
Natural grass, crushed granite - not suitable for pool surround due to debris migration.
Concrete - hot to touch, hard, and non-permeable; high clay content around here, so movement in concrete very possible without substantial rebar.
Natural stone, or brick - more expensive than concrete/fake grass, hard, hot.
My research tells me the higher quality residential stuff includes some/all of these visible features:
1) Has texture to individual blades. Take a look at some real grass, some have a spine...in high quality grass, they recreate the spine.
2) Color variation among blades. I've seen two-three shades of green.
3) They also can include a "dead" grass, thatch, for realism (not weeds as someone stated).
4) Varied length
5) Varied width, both individual blades, as well as wide at base and narrow at tip.
6) Some are notably softer to walk on than others, but don't know what material makes a good surface.
That picture seems like the better quality stuff, not the highest, but most likely >$10/sqft range. It doesn't appear to look good as pictured because it's not completely installed. The blades are still leaning as it was just unrolled. There's also no infill to perk them up. What makes me think it's a better quality turf is the presence of a backing layer, both for comfort and for protection of the weave (this is an example of a non-visible advantage). Imagine the abrasion to the weave happening without the additional protective layer.
As for looks of the fake grass, when the neighboring trees drop their leaves and twigs and I let them be instead of sweeping them up, the solid green carpet suddenly looks more real...at least that's what I've been doing with the grass samples I've been given. Doesn't look bad at all.
