Guys/Gals just read this on another forum and not sure if you are aware of this new proposed rule change by the ATF. Posting a link to a site with a pretty good explanation of the changes and it also has a link to make your voices heard to try and stop this gross overreach by the ATF. They basically want to make almost all parts of a firearm serialized which will require a FFL transfer for almost all firearm parts. I mean good lord here is a quick excerpt from the proposed ruling.
For purposes of this definition, the term “fire control component” means a component necessary for the firearm to initiate, complete, or continue the firing sequence, including any of the following: hammer, bolt, bolt carrier, breechblock, cylinder, trigger mechanism, firing pin, striker, or slide rails.
Help out and post a reply to the proposed rule changes so they know we don't want this to go into effect. Hopefully with enough public comments against it they will dump this in the circular file where it belongs.
