Clash of Clans
Wasn't my screenshot, but next time i'll ms paint it out ;) although my lack of skills may cause more issues with OCD.
I really hate Clash updates. just when you start doing good in war they come up with new defenses to stump you. I'm a mid level TH10 and its pretty damn hard to 2 star a similar level th10 in war if they have one of those anti gowipe bases. Hell I even got LV5 dragons and only got 47% just earlier. Fucking frustrating.
Frustrating, but it goes both ways. When they first did the update that made it so you couldn't draw heros out tot he edge of the map, everyone got upset. We found ways around.
When they updated the big bombs to cause a modifier against hogs that wiped out hog raids, we found ways around.
It's frustrating, but it keeps you having to adapt, which keeps the game fresh. Otherwise, everyone would always do the same darn raid.
I now have both Infernos to level 3, all three xbows at 3 all four wizard towers to 8, all four teslas to 8 and am starting on the archer towers to 12. I don't get raided much anymore and when I do, they usually only get one or two storages. Rearming traps cost me than they take from me, but someone managed to hit me for 74% with max giants and archers and got all of my storages (which are well spread out). He used a lot of freeze spells and rage spells and carved his way deep into my base, so there are always ways.
I've learned a lot more about raiding pushing for trophies.
One of which is to not mess with inferno towers. lol
Since my trophy push to champs, Infernos don't scare me anymore. I give no respect to infernos set to multi when I run a loonion raid and Giant/archer will overwhelm a single. If things look real tough, I'll use the freeze spell, but usually not.
177 inferno towers killed so far.
well there is your problem right there, you use a gowipe and dragons.
I have a ways to go. I've only got 39.
Only 64 here.
I tend to avoid them unless it's worth the loot and i can have a clear path of attack to get rid of them. Without a freeze spell, it kinda sucks. And i usually run gibarch with all heals in my inventory so that doesn't work either lol.
I think most of my kills were when i was loonion'ing up in masters.
Only 64 here.
What level are your hounds?
I am finding that my hounds don't last long against infernos so I still avoid them where possible.
I'm in the middle of unlocking level 2 but not sure if they will give my loons enough time to break them down before the hounds pop
So, how do you actually do a loonian attack? I have max loons, but I have no idea how to use them. What is your army & spell distribution? Do you rawk a bunch of healing spells to heal up the loons as they go through the base, and once the air defenses and archers are toast, let the minions loose?
I've just been BARCHing away this whole time, and I occasionally just GoWiPe or GoWiWi when I get bored. Every time I try a balloon attack, I don't get very far at all.
I suck with balloons, too. largely because I NEVER use them. Same with drags.
Wow 4 earthquake spells are OP and only take up 2 normal spell slots. Try it all in one place and I guarantee everything in that one spot is dead. No need for jump spells anymore!
i used to go 2 rage 2 heal, when i go with hounds it is 3 rage 1 heal.
for a quick attack 16 loons 60 minions all the way up to 28 loons 30 minions. or 20 loons 1 hound 45 minions.
I usually go 40 minions and the rest loons. 2 heal, 2 rage. Always try to lure the cc troops out first with like 3 loons to take out at least one defense while luring out the troops.
Then, pick an attack side and deploy the loons, then almost immediately after, drop the minions.
You almost always have to use at least 2 spells. Just depends on what you need, either heal or rage.
Max loons and L5 minions is almost a guaranteed 50% against TH9's
I was going 30 minions, but i get so much DE, i'd rather save on elixir. Plus it's faster to rebuild the army.
I only use hounds in war, and i've sucked horribly each time. Just too expensive and takes to long to cook for farming.
All my troops are TH9 max (drag 4 is cooking currently in lab).
I should start practicing though. So many ways to attack....holaloon, fractured attack, surgical lavaloon. Almost always 4 rage spells. (Except holaloon, heal the hogs to get that AD)
Ditto, except I normally go out with 2 rage.
I boost regular barracks, spell factory, and one dark barracks. In the boosted dark I have hounds and in the regular dark I have all minions. Then in cc just ask for max minions.
Wait for hound to engage then drop loons. Wait for them to clear parameter defenses and drop minions. Drop Heros on the perpendicular corners. Meaning if you are attacking with balloons from 3 to 9 in an arc have the Heros be at 3 and 9. So everything attacks up to 12.
Rage the loons at the teslas or xbows
My clan FINALLY got Perk 5. We are taking a break from war, and just letting the max troop donations flow.
I think warring 3 times a week burnt us out, along with a bunch of newly started TH9 grinds.
*breath*
Our trophy push is over. Highest was 137 Global.
Now it's back to farming for gold to get my xbows finally
