This thread has pulled in a number of ideas on throttle use and turning, which may relate back to the OP's incident in some way. The questions that have emerged that I have an opinion about are:
1) What should a rider be doing with the throttle in a corner?
2) Does a bike turn via leaning or steering?
3) Why doesn't Keith Code teach trailbraking?
The answers to many riding questions can depend on what the rider is trying to do in a given spot. The situation the rider is in will play a role; e.g. a severe downhill approach to a decreasing radius turn may call for different uses of throttle and brakes in different parts of the turn than you'd use in a flat, on camber 90 degree turn.
Keith Code's Superbike School is a program that, among other things, teaches the rider how to get the best handling and traction out of his bike. The bike delivers the most traction that it is capable of under light acceleration. This distributes weight in proportion to contact patch size and places the suspension in the middle third of travel, where it works best. The program at CSS is oriented around tactics and control operations that serve this goal.
Trailbraking falls outside of this scope. This is not a criticism of the technique; it has valid applications. But it's not a technique that makes the bike work at its best. It's a technique that deviates from optimum handling and traction to serve another purpose that may be more important in that situation. Passing on the brakes is the obvious example. Working DR turns can be another.
A rider is best prepared to deviate from optimum conditions after he has mastered producing optimum conditions. In terms of outright speed, if a rider is four seconds off the pace in his class, he has more to gain from working on his throttle control than he does from braking deeper. That's not to say there's nothing for him to gain from later braking, but the big gains aren't found there and the rider may adversely affect his lap times if he doesn't approach his braking in a disciplined manner.
In terms of racecraft and gaining positions, braking is crucial. But riders who can get the most out of the bike in ideal conditions will get more out of actions that deliberately depart from ideal. Keith understands deep, late braking and teaches these skills in the Code R.A.C.E. program.
The framework I apply to street riding in normal circumstances is to use the techniques that get the best handling and traction out of my bike. With that in mind, whenever possible, I make a single steering input per turn to put the bike on a line that allows proper throttle control. To me, proper TC is cracking the gas on as soon as I set the lean angle and gradually rolling on through the turn. My roll-on begins long before the apex.
On the matter of whether a bike turns due to leaning or steering, I was surprised to read Holeshot's assertion it's the latter. A turning motorcycle is a complex thing; harder to understand than a car, I think. We can take isolated examples to highlight certain aspects of it, but a number of things work together and they sometimes seem to contradict. I'll see if I can explain my own understanding.
First of all, a motorcycle cannot turn without leaning. At the very least, leaning is necessary to keep cornering grip and centrifugal force in equilibrium. The question is, does leaning actually cause the bike to turn?
If you take a tire, lean it over 20 degrees and set it to rolling, it turns. That seems to imply a motorcycle would too. OTOH, when riding a motorcycle slowly, it's dead obvious you have to point the front wheel into the arc when you're turning. These ideas seem to conflict, but to me they reconcile pretty well.
When you turn a bike, it (or you) must lean. Whether you lean with the bike or against it, the combined center of mass of you+bike will be inside the arc the tires are traveling on. Turns on motorcycles are *always* initiated by leaning the bike, however it is you do that. And if you're going around a turn with the bike vertical, you're leaning your body to the inside. There's no getting around it.
Once the lean is initiated, the front tire does have to point into the arc. It must do so in order that both tires can follow the same arc. You wouldn't be able to expect the front and rear tire to track an arc if they were aligned on a vector. They must be aligned on the arc.
When riders initiate turns slowly, it can be difficult to determine whether the bike leans before the front wheel must turn into the arc or not. If you initiate a turn very quickly, you can easily tell that the lean angle sets first and the front wheel must then turn in to follow the arc.
