Save your $10...
I wish I did.
I second this notion...
Save your $10...
I wish I did.
It's important to remember to try and get your motor right on top of the line that marks where the sensor is, not in the middle of the circle or the square that the line creates. The wire pickup that senses a vehicle is actually under the line you see, so if your motor is in the middle, the sensor has a tougher time sensing you. Does that make any sense?![]()
i put some Neodymium magnets on the bottom of my bike...
helped me with a bunch of lights, not all of them though...
I might buy a couple more and putting in the back of my fairing as well...
Press the starter button.If you're on a motorcycle you can pull in the clutch, stop the engine, and press the engine starter button. The starter is powered by an electromagnetic motor, creating more magnetic energy and tripping the sensor.
I wonder if he would trigger the sensor if he laid on the ground in the middle of the sensor and rolled around?
CVC 21800 (d) FTW!!
The driver of any vehicle approaching an intersection which has official traffic control signals that are inoperative shall stop at the intersection, and may proceed with caution when it is safe to do so.
Any signal that has a trigger, and won't recognize your legally registered vehicle, may be considered 'inoperative'.
My VTX always triggers green lights
anyone carrying a 2lb block of steel around?
dropped a couple of the ball bearings
and on some other lights it seems like nothing on a motorcycle will ever trigger it.
good for you Reckonbeat me to it.
a cop once ticketed me for "running a red light", after I sat at that thing for 4 light cycles (almost 16 minutes), got tired of waiting, and just went when it was clear.
he even said he was watching me, waiting for me to run it. I asked "well, what are we SUPPOSED to do"? and he actually answered "go another way"
that did it, I looked up that very CVC section, and videotaped an hour of that light, including 30 minutes of me sitting at it, trying to get it to trigger green.
then I took the cop to court, and the judge dismissed it after seeing the tape.
the magnet thing, like the kickstand/starter trick only works on SOME lights,...and on some other lights it seems like nothing on a motorcycle will ever trigger it.
anyone carrying a 2lb block of steel around?![]()
Traffic monitoring as far as what? Anything more than just volume of traffic?
I'm always interested in what Oakland is doing... the shot spotter stuff is pretty interesting.
will help.![]()
I dunno, usually I do okay waiting the couple of light changes and sneaking through. One time in SF, though, the cross traffic was way too heavy, so I finally put down the kickstand, dismounted and ran over and hit the pedestrian
I know a guy (doesn't ride) who lines his boots with magnets because he thinks it makes his feet feel better. He also has a vest with magnets sewn all through it because he claims it cures his back aches...
