OK smartypants. I guess in YOUR car, if you turn the radio on, your engine burns more gas.
rofl
Zed10R,
Turning on the radio actually
will reduce your fuel consumption, although it will be by an insignificant amount. Remember that the radio draws a very minute load compared to some of the other electrical devices on a vehicle (how long could you listen to the stereo with the engine off, vs how long could you leave the lights on before the battery dies?) In some cases, however, the stereo can have a real impact. Installation of sub-woofers and amplifiers may require the addition of a heavy duty alternator and capacitors to handle spike loads . In many cases, te sub-woofer can void the warranty on your alternator, because the high electrical demands can burn a stock alternator out.
Regardless, I think some experience with generators will help you wrap your head around this one. Generally, plugging a high load into a generator will have a significant impact on the engine speed. Usually RPMs will drop noticeably along with voltage until the carburator / ECU compensates by supplying more fuel/air mixture. You will not be able to stall a generator by placing too high a load on it simply because the alternator is NOT over-engineered for the engine driving it. Typically, they engine is capable of producing more rotational energy than the alternator is capable of converting into electrical energy.
On a car, you will not be able to stall the engine by turning on extra lights simply because the alternator is not capable of putting that high a load on the engine. If you managed to overload the alternator without blowing a fuse, you will probably end up with a low power situation, eventually followed by a dead alternator.
There are many methods to control idle speed. The ECU on most modern cars will monitor idle speed, and open a circuit that bypasses your throttle in order to keep idle within spec. Idle should not drop noticeably unless a very large load is applied. On a modern motorcycle, idle is usually controlled by a simple throttle stop screw, although the ECU sometimes has control of an enrichment circuit, or the secondary set of throttle valves. On a bike, load may effect idle.
The most important thing to note is that modern car alternators are usually capable of supplying about 80-150 watts, when running at optimal engine RPMs (which is usually WELL above idle speed.) A quick calculation shows that even at peak output, a 40% efficiency a 150 watt alternator will not draw more than
half a crank horsepower. That's hardly enough to be noticeable.
For comparison, you might gain a full horsepower by driving in 10 degree cooler weather.
Phew... After writing all that, I'd appreciate some research and thought experiments before responding.
