Agent Orange
The b0y ninja
Good God, I was only 4 when in 1984! =P
christofu said:That doesn't mean anything because we all know that the french are just plain crazy
I've driven in Paris several times and lived to tell the story. Barely![]()
Mstingray said:ah, k. i also tend to use alot of engine braking as well.
well, the engine can only wind up so high right? so if it's almost at max revs and you're downshifting, wouldn't it screw up the bike?(e.g. 10k RPM (almost rev limit on TLR) on 3rd gear, then downshift to 2nd.) i'd imagine it'd lock up the rear, make it start skipping and/or just totally fuck up the engine/tranny/internals.
Baptistro said:
Now, I am still not understanding christofu's method of blipless downshifting, no need to dowshift unless you're slowing down, or planning on slowing down, unless you messed up and are in the wrong gear (let's keep this last one out of the scenario). You must be letting off the gas as you downshift right? You are then regulating the throttle. The mere act of engaging the clutch is automatically gonna bump the revs momentarily, if the throttle is steady, allowing you to bump down a gear and disengaging the clutch. Have I got it straight so far? If this is what you're doing, it makes perfect sense, except I would assume that you would need to be completely familiar with the machine to be able to do that ona regular basis, as well as knowing the track you are on and the speed you take each turn at exactly. Do you change the gearing on your bike from track to track? If so, do you find that you are more comfortable doing this on one track as opposed to another? I would imagine that it would change your power band considerably depending on your gearing changes, and, as such, would require you to adjust how you riude the bike, including how and when you downshift. Once again, am I talking out of my ass?
christofu said:Bap, I guess I am "regulating the throttle" in the sense that I'm completely closing it and leaving it completely closed throughout the entire downshift process. That is, completely release throttle and don't open it again until you're in the turn. Hit the front brakes as hard as required, and continue braking at constant pressure. Now ignore your right hand.
Clutch in, downshift, clutch out. Clutch in, downshift, clutch out.
As you say, even if you're at redline, just letting off the throttle and momentarily pulling in the clutch for the downshift will automatically drop your revs dramatically, not to mention that you're also on the brakes.
I think you're thinking this a lot more complex than it really it. In reality it's a LOT easier than trying to blip, brake, downshift all at the same time. At least the way I ride, the key is trying to simplify. If I can get the same (or in this case better) effect by using fewer controls then that's definitely a good thing.
While it is in some respects related to gearing, etc, that really plays no major part. It takes just a few corners to get the hang of the downshifting/rev/clutch relationship on a new bike.
Are you going to be at the Oct 16th track day? I'll demontrate.
Baptistro said:
On your bike, do your revs stay pretty high even when you let up on the gas? Would you try the same method on a big twin with a dry clutch? I mean, how big a part of this equation is equipment?
, I will definitely give it a shot, maybe even tonight winders said:
He taught me to downshift as the revs allowed while braking. And if I downshifted a little early, so what? Let the engine rev out a bit. If the rear end starts to chatter or move around too much, feather the clutch.
Ace of Hearts said:BINGO!!!!!!!!
Thats what I do. At least that best describes what I THINK I do.
I will be hauling ass, go from full throttle to ZERO throttle, and apply brakes. When slowed down enough I will down shift to match speed/revs. I will do this until I am set up for the turn. At which I stop shifting through the turn. Any gear changes I need to catch up on are done as I exit the turn and try to get back to FULL throtle again.
It sounds to me like this blipping thing is for correcting for down shifting too many gears. When you go down too many you tie up the rear and need to bring the revs back up to keep it from locking up.
Robert R1 said:How do you keep your bike at 8or9,000rpms, brake hard with a shut throttle, pull in the clutch, downshift and release without blipping. Revs drop fast the moment you touch the clutch or get hard on the brakes. Your clutch must have you if have to keep riding/slipping in the whole time to build up revs.
Resurrecting a thread from the dead, but does anyone do this (downshift and brake with rev-matching) on the street (for practice for instance)?
I have small hands and while I could do this on a scooter in SE Asia I can't seem to get it right on the bikes here ...
Yes, frequently. Pointer and middle fingers actuate the brake, while the thumb, ring and pinkie blip the throttle. Yes, it takes practice (and properly adjusted levers) to get good and smooth at it.
