Quick IQ Test...
The ones that really stumped me were the circle ones (one solid, one with a < in it, the other 6 empty) and the other circle one with the little squares either filled in or solid, inside or outside the circle, and of course the last one.
Palindromes might be a test of intelligence, but who knows...any teachers debunk these hieroglyphic type iq tests yet?
That palindrome was created by Bob.
This one?
A.
B.
C.
D.
Answer is A.
It can't be a blank circle because that messes up the pattern. It could be C or D, but that wouldn't exactly hold a pattern either. A is the best answer because it allows for a unique circle in each row and column. IOW, no repeats.
^^^Ahhhh, makes perfect sense, I missed that one. Anyway, fun little test that was nice and short, just like my attention span. "You have reached 14 points and your IQ is: 125 "
My coworker went through and found all the possible combinations. There's no way to get 20 points. Some answers are worth 2 points and some questions have more than 1 correct answer
sounds like another guy who scored higher than you :twofinger
Really? Which ones have more than one correct answer?
Dunno. Its Saturday. Ill see him on Monday and we all probably wont care about this by then. :)
Answer is A.
I can't see how that answer - or any answer - is very compelling. With only two non-blank images, who's to say what "pattern" is there or that "no repeats" should be the theme? If the point of those two images is simply to be different, that seems a bit weird because then the chosen image contents are otherwise completely meaningless.
It's the one that fits the best. You may not see it, but that's the pattern.
