RZ350 TZR 3XV Hybrid
Frame Maker welding, assembling, and installing a master piece of metal work on Super Sunday. And a “solution” for the upper shock mount is designed.
[youtube]zSy-2PDfGhg[/youtube]
2/19/24 EP15
Engine disassembly begins.
[YOUTUBE]yjXecaiJxwc[/YOUTUBE]
Taking squish band measurement.
A rare shot of the rookie mechanic in Ken’s Garage
Damn damn damn.
Heart and soul at work. :thumbup
From the look of the pistons, head, and bore, it looks like that motor has not been run on that top end. Good stuff if in tolerance.
I've never used pennies for the primary gear jam. We always used a rolled up rag.
I always enjoy your posts! Thanks.
Nice work, that's a delightfully clean lump. How much squish are you running on the 350? Are they stock heads?
Thanks for the comments folks!!!
Joe, squish band measurements are in the video. I guess you'll have to watch it.:teeth
2/25/24 EP16
[YOUTUBE]EBhLGeHx8sU[/YOUTUBE]
Back to Frame Makers to install upper shock mount brackets.
Things went swimmingly until we tested the rear suspension. It barely moves. Julian has determined that the heavy aluminum lower arm (fabbed and set up buy someone else) is too short. The suspension is unable to work properly and will need further mods. Damn.
