10/2/22 - 10/6/22
All radiator and coolant hoses installed.
16T countershaft sprocket installed.
Clutch side cover and stator side cover installed. Secondary covers on the clutch cover need refinishing. Also it looks like I probably should have used high gloss paint on the clutch cover because the oil pump/water pump cover and the other Yamaha cover are high-gloss and not a match. Maybe I will take out the scratches and paint them to match the clutch cover. Maybe. And that kick starter really looks a bit out of place with its olive drab plating faded out. Must fix that.
Stator (high-gloss) cover cleaned up beautifully after 1-2 hours of monkeying around with different “restoration” techniques.
New Yambits power valve cables not fitting. Cannot be properly adjusted with backing all the way out of the threaded portion on the head. Need to find spacers. Looks like I need “slotted step down adapters”. Or M6 threaded adjuster that I will cut a slot into.
I really need something like this which is on the oil pump cable on one of my bikes.
A search came up with Venhill my favorite brake line supplier call tomorrow STEEL ADJUSTER SCREW M6 x 1.0 X 20mm
I tried Flanders but their website doesn’t work for ordering stuff so I’ve called them twice and they are “unusual” to work with on the phone. When I mentioned I wasn’t able to order off of the website the dude said something like “yeah that doesn’t really work does it?”
In the end a week and ½ laterI ended up ordering some slotted bicycle cable adjusters from eBay so now waiting for those parts.
