DTM74
It's not my fault...
Do tenants get relocated during projects like this? Imagine if someone fucked up and there was a collapse with people living there. Yikes.
Someone go up to the top floor and tell Joe to gather his shit. LOL
That's up to the city. If SF red tags the building, you bet they get relocated. I've seen one inspector close down a 30,000 square foot structure.
The city will issue a permit for the work to be done and make a call at that point. Depending on how far, if at all, the subsidence has proceeded, they may or may not. I would doubt that they will move anyone unless the building is declared a hazard. If that happens, there's going to be hell to pay for the neighbors as well.
Where the fuck are they gonna relocate to? We're in something of a housing shortage as it is and I'm pretty sure someone living in a $3m apartment isn't going to settle for some old creaky leaky rent controlled $800/month SF apartment.
to their *other* pied-a-terr of course.
http://phys.org/news/2016-11-sentinel-satellites-san-francisco-millenium.html
A little help from space. Sinking at a rate of just about 2"/year.
Every workday, I look across the street at the Tower and wonder... When?![]()
Sounds like someone trying to drum up work for their expensive satellites.
You don't need to go into space to measure the lean or the settlement of that thing.
Simply mount a prism at the top and another near the bottom. Shoot them with a total station every week or two and compare movement relative to each other and to a few fixed control points on ground.
It will accurately measure any movement within a few mm. No need for rocket science.
The problem with fixed ground points is that the entire neighborhood is fill. You can't be sure what fixed means. (We have houses in Oakland and Berkeley that have moved 2-3 feet downhill in their entirety)
There are numerous methods that could be used. San Francisco has a bunch of places of elevation that have bedrock close to the surface that are in line of site of the tower.The problem with fixed ground points is that the entire neighborhood is fill. You can't be sure what fixed means. (We have houses in Oakland and Berkeley that have moved 2-3 feet downhill in their entirety)
