Climber
Well-known member
The building code isn't going to solve every construction problem, especially for the heaviest fucking building ever built there!From what I've read, current building code in SF does not require the foundation to meet bedrock. In my opinion, code should require it given that the tower is on bay fill, but it doesn't. The builder followed the code requirement for the foundation
The developers are blaming the transbay terminal construction, as they pumped millions of gallons of water out of the ground, which lowered the water table and made the ground sink.
Everything comes back to the building code.
I don't agree that since building code allowed it, that taxpayers should be required to pay. That's just fucked up thinking! The building code wasn't created to act as a guideline (and liability for taxpayers if it isn't sufficient) for how to build building, it was created to apply a minimum standard, but the burden should be on the builders to properly design and build their building.
When you push the fucking envelope and it doesn't work out, you shouldn't be able to push your losses onto other people.
